3-Point stuck UP !
   / 3-Point stuck UP ! #1
Scrambler82
Veteran Member
SoCal
Mahindra Max 28XL, HST, TLB
I walked out to the Tractor this AM, was going to hook up the Grader/Planer and run over the road.
As I approached the tractor I noticed I must have forgotten to lower the 3-Point last night, no biggy, I push the lever to lower it, without the engine running and nothing happened. The Brush Cutter didn't go down ?!?!?!? Puzzeled !
I started the tractor, but nothing changed; before I start tearing apart my Max28, is there anything I should know, a safety Valve maybe, a lever I didn't know about... hoping for something little.
Thanks for any assist !
   / 3-Point stuck UP ! #2
Did you put Viagra in the fuel last night?
On a serious note: Did you try to raise then lower (engine running)?
   / 3-Point stuck UP ! #3
Did you check the drop rate valve? usually in front of the seat...?
   / 3-Point stuck UP ! #5
   / 3-Point stuck UP ! #6
So do you have to wait up to the 4 hours? :)
   / 3-Point stuck UP ! #7
Oh, and I forgot to mention: the WHY? did the valve get turned in the first place? You accidently turned it with your foot getting on or off of the tractor.
I put some Viagra in the fuel tank, hoping to get the little Tractor to have little more push... that didn't help !
Yes raising and lowering the lever was the first reaction. Engine running and not running.
I tried to move the valve but to tell the truth not sure if the tractor was running or not. I will attempt again today.
I know this link is for a Kubota, but this might be the issue as pointed out in previous post
The most MISUNDERSTOOD control on a tractor - TMT - YouTube
I watched the Video, I will try again this AM.
I got one caught in my throat and had a stiff neck all day... LoL !
Also, is your Handle (K0UA) a Ham call sign... ?
Thanks for all of the suggestions,I need to get it working today, got to get the Grader/Planer going !
   / 3-Point stuck UP ! #9
Yes, I am KØUA.. you can look me up on QRZ
   / 3-Point stuck UP ! #10
For me it is when I turn to look behind me to back up. :D
7599 (A47384)
7599 (A47384)
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2014 Jeep Cherokee Latitude SUV (A50324)
2014 Jeep Cherokee...
FORD 3000 TRACTOR (A51243)
FORD 3000 TRACTOR...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
