3-Point Hitch 3 point sticking up.
   / 3 point sticking up. #1
lrs
Spokane, WA
New Holland
Have a problem with my TZ25DA. Tried to put on the mower deck and cannot get the 3 point lift to go down. Put weight on it and nothing.
   / 3 point sticking up. #2
Adjust the drop rate valve under the front edge of the seat counterclockwise to release the fluid.. You have bumped it with your foot accidently. and the fluid cannot escape the cylinder back into the tank.
James K0UA
Thank you. Works just fine.
   / 3 point sticking up. #5
That was pretty darn fast help!!!! :laughing: Thought about saying "What took you so long?" ;)
BTW, Welcome to TBN!!! :thumbsup:
   / 3 point sticking up. #6
2 minutes is not too bad...:) That closed drop rate valve thing ought to be a "sticky" :)
James K0UA
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E50NKE58889, Super Cab, 4 x 4, 5.0 L V8 Gas Engine, (A59076)
2022 Ford F-150 XL...
1998 INTERNATIONAL 9400 (A58214)
1998 INTERNATIONAL...
Behringer 19 high x 43 wide Metal-Cutting Bandsaw (A59213)
Behringer 19 high...
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A56858)
2012 Freightliner...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
