3 point shield
/ 3 point shield #1
ChuckT
Central Florida
Yanmar YM1510D
Our 1510D is a 2 point to 3 point conversion and has a set of long stud surronding the PTO output shaft.
How much trouble is it to to get those studs out? I'd like to fab. a 3 point shield & replace the studs with short hex bolts.
TIA
cvt
/ 3 point shield #2
ChuckT,
I believe there are four studs on your model and they are set into the hydraulic case. They serve as a guide when R & R'ing the PTO housing.
I would use the large hex nuts on the studs to hold down a shield rather than replace the studs with bolts (IMHO).
Mark
/ 3 point shield #3
I have removed studs by using two nuts and jamming them together very tightly and then using a socket or wrench on the outter nut to unscrew the stud.
/ 3 point shield #4
Actually, you should be turning the inner nut to remove the studs in this manner, and BTW, it works very well! /forums/images/graemlins/smile.gif
/ 3 point shield #5
Chuck, when you remove them studs, I believe hyd. fluid will flow out.
Ernie
/ 3 point shield #6
Didn't on my 1602D, is it made differently? I get so confused by these numbers, as to which is the larger frame but 2 cyl engine vs the smaller frame and 3 cyl like I have........
/ 3 point shield
I want to remove the studs and replace them with short bolts. Then make a PTO shield out of aluminium or light steel that would use some of them them as the mounting points (for the shield).
I'm not sure if I know Yanmars well enough to judge "large frame" versus "small frame" but our 1510D is a smallish (as compared to the other models I looked at) 3 cyl., 4wd.
cvt
/ 3 point shield #8
Well, I took them out on my 1602D with no leakage or other adverse effects, FWIW. I think you should be able to do the same..... you can see the holes where I removed the studs in this pic. I don't use my PTO anymore, since I don't mow or brush hog with it anymore, so i don't have any shielding.
/ 3 point shield #9
Chuck, trust me and be sure to have a catch pan under the pto shaft when you remove the bolts.
Ernies Imports
/ 3 point shield #10
Well, Ernie should know, so I'd follow his advice..........
/ 3 point shield #11
Please dont ask HOW I came across this info /forums/images/graemlins/blush.gif
/ 3 point shield
Okay - the studs should come out with effort & put a pan underneath to catch the fluid - I can do that.
Thanks to all.
cvt
John Deere 7230 (A62180)
John Deere 7230...
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2021 Sol Grand Design BK390 Camper (A62613)
2021 Sol Grand...
