3 point shield
   / 3 point shield #1
ChuckT
Central Florida
Yanmar YM1510D
Our 1510D is a 2 point to 3 point conversion and has a set of long stud surronding the PTO output shaft.
How much trouble is it to to get those studs out? I'd like to fab. a 3 point shield & replace the studs with short hex bolts.
TIA
cvt
   / 3 point shield #2
ChuckT,
I believe there are four studs on your model and they are set into the hydraulic case. They serve as a guide when R & R'ing the PTO housing.
I would use the large hex nuts on the studs to hold down a shield rather than replace the studs with bolts (IMHO).
Mark
   / 3 point shield #3
I have removed studs by using two nuts and jamming them together very tightly and then using a socket or wrench on the outter nut to unscrew the stud.
   / 3 point shield #4
Actually, you should be turning the inner nut to remove the studs in this manner, and BTW, it works very well! /forums/images/graemlins/smile.gif
   / 3 point shield #5
Chuck, when you remove them studs, I believe hyd. fluid will flow out.
Ernie
   / 3 point shield #6
Didn't on my 1602D, is it made differently? I get so confused by these numbers, as to which is the larger frame but 2 cyl engine vs the smaller frame and 3 cyl like I have........
   / 3 point shield
I want to remove the studs and replace them with short bolts. Then make a PTO shield out of aluminium or light steel that would use some of them them as the mounting points (for the shield).
I'm not sure if I know Yanmars well enough to judge "large frame" versus "small frame" but our 1510D is a smallish (as compared to the other models I looked at) 3 cyl., 4wd.
cvt
   / 3 point shield #8
Well, I took them out on my 1602D with no leakage or other adverse effects, FWIW. I think you should be able to do the same..... you can see the holes where I removed the studs in this pic. I don't use my PTO anymore, since I don't mow or brush hog with it anymore, so i don't have any shielding.
   / 3 point shield #9
Chuck, trust me and be sure to have a catch pan under the pto shaft when you remove the bolts.
Ernies Imports
   / 3 point shield #10
Well, Ernie should know, so I'd follow his advice..........
2005 Manac AAF-48 50 Ton Flatbed Equipment Trailer (A51692)
2005 Manac AAF-48...
2015 Caterpillar 410L 4x4 Extendahoe Backhoe Loader (A51691)
2015 Caterpillar...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
2025 CFG Industrial QK20R (A50123)
2025 CFG...
2012 FORD 4 DOOR TAURUS (A53426)
2012 FORD 4 DOOR...
2002 International 9200i Truck (A53473)
2002 International...
