3 point rookie
/ 3 point rookie #1
vaj
Lagrange, NY
JD 310d, JD 4110
Just received my first 3pt attachment, a landscape rake with wheels. I have a jd4110. Got it hooked on and the 3pt is spread so wide if I turn at all it rubs the rear wheels. I am embarrassed but what is the trick I am missing?
Thanks
/ 3 point rookie #2
You should have anti sway chains to tighten up on your tractor 3 point. This will probably take up the slack--Ken Sweet
/ 3 point rookie #3
If Ken's suggestion does not work I have seen the pins moved to the inside of some implements for more clearance
/ 3 point rookie
Thanks I got it
The dealer had those so crooked it is amazing I was able to attach the thing at all in the first place.
/ 3 point rookie #5
vaj, you have to tighten the turnbuckles that are attached between a horizontal shaft on the back of the tractor and each lift arm. Otherwise, the attachment on the 3 ph can swing back and forth, and, yes, rub on the wheels. I had to learn the same lessons until I coded it into my brain to always tighten the turnbuckles.
I threw away those little cotter pins that were included with the turnbuckles and just run some tension straps between the turnbuckle and the ROPS assembly to keep them from turning once tight.
Ralph
/ 3 point rookie #6
Ralph...what a great suggestion. I keep loosing those clips and with your idea I can throw them away....THANKS!
1991 25ft Wellcraft 250 Sportsman Boat with 1980 27ft Float-On T/A Boat Trailer. (A61574)
1991 25ft...
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
2017 Forest River Rockwood HW275 S/A Pop Up Camper Trailer (A61574)
2017 Forest River...
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
HI-PRO PTO PUMP (A64280)
HI-PRO PTO PUMP...
