3 point resists when lowering.
   / 3 point resists when lowering. #11
On the the B7000 I had and pretty sure the B7100 too, there is a rod connected from the right lift arm to the lever. On this rod, there are two adjustable stops. One sets max height, the other sets how low it goes. Once it hits the stops, it will kick the lever to the middle. You may need to adjust the one that sets how low it goes.
EDIT: The wrench needed is either 10 or a 12 mm. It's been a while since I owned that tractor.
  • Good Post
Reactions: JWR
40' High Cube Multi-Door Container (A53314)
40' High Cube...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
20205 Lucky Dak Electric scooter (A55853)
20205 Lucky Dak...
UNUSED WOLVERINE MSG-11-44W 44" HYD STUMP GRAPPLE (A57193)
UNUSED WOLVERINE...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
