3-point rake question
/ 3-point rake question #1
Ricn
Platinum Member
WA
Kubota U-35, kx-040, Ford 8n, JD-280, JD380, JD1020, JD40C, Satoh Bull, Kubota L2501,
I need a Cat-1, 3 point rake for my L series Kubota; can you guys recommend
one that will last? How about the tines, do they break easily? Never using one
before so have no experience. Will they take fist size rocks without breaking
if using low gear? Thanks for the suggests and education.
Ricn
/ 3-point rake question #2
What type of rake are you looking for? Landscape, hay, lawn cleaning?
Assuming landscape rake they are very durable. I pull a 6' King Kutter and it does very well. Never broken a tine, fist sized rocks are no problem, 50 lb rocks makes it work a little.
Settings are the key, i.e. angle, forward/back tilt engagement of the tines, adding extra weight to make it dig a little, etc.
/ 3-point rake question #3
Ricn
Everything Attachments. I totally abuse mine and it is holding up like new.
Being ignorant of this, I will say my plans are to rake brush and sticks with maybe 4 inches of depth into the dirt and why I mentioned fist size rocks. If going to deep they get bigger sometimes. Once cleaned up a little, we plan to plant pasture grass for our small beef herd to have more graze next year, once the grass is strong enough for their weight. This area of about 2 acres is one I logged maybe 10 years ago; our Son just finished removing all the big stumps using the excavator. We now has lots of rocks. sticks and loose brush laying around from all the digging. Steppenewolf: thanks for the link, looks to me something there should work for us.
Ricn
/ 3-point rake question #5
For what you are doing almost any landscape rake will work. Since there is no down pressure on the 3 pt it will float up over obstacles unless you do like I do and add some weight sometimes. Still they are pretty tough and should not get damaged with the tractors you have listed. And yes a landscape rake is the right tool unless you get a power rake like a Harley rake.
Agree with Steppenwolfe - Everything Attachments is a good company.
/ 3-point rake question #6
If you find you are carrying too much dirt to your burn pile, remove every other tooth. That always works for me.
/ 3-point rake question #7
Look at the videos on Everything Attachment's website, they have a video on how to use the rake. There are many good videos on that site. And, they have the best attachments for the right reasons. Call them, they will give you the best advice.
/ 3-point rake question #8
Here is their new heavy duty model: http://www.tractorbynet.com/forums/...ark-hydraulic-landscape-rake.html#post4464026
/ 3-point rake question #10
Being ignorant of this, I will say my plans are to rake brush and sticks with maybe 4 inches of depth into the dirt and why I mentioned fist size rocks. If going to deep they get bigger sometimes. Our Son just finished removing all the big stumps using the excavator. We now has lots of rocks. sticks and loose brush laying around from all the digging.
I own both an ETA Landscape Rake and a Ratchet Rake FEL bucket attachment. For the uses you have specified, the Ratchet Rake will be more effective than a Landscape Rake. Ratchet Rakes can be purchased from the T-B-N store, delivery by common carrier.
I have used Ratchet Rakes on both my relatively light Kubota B3300SU and my heavier Kubota L3560.
LINKS: Google:Ratchet Rake
/ 3-point rake question #11
Great idea!! :thumbsup:
As simple as it is, I never thought of doing that. I'll try your suggestion next time. I'm always having the problem of dragging dirt and ashes to the center of the burn pile.
Jeff, thanks for the pics on ratchet rake, might be the best choice although and like you, having both would be better!
Regards,
Ricn
2005 VOLVO EC290B EXCAVATOR (A59914)
2005 VOLVO EC290B...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
Mini Universal Tree Spade (A65640)
Mini Universal...
Informational Lot - Shipping (A63689)
Informational Lot...
2012 Chevrolet Colorado (A64194)
2012 Chevrolet...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
