3-Point Quick Hitch
/ 3-Point Quick Hitch #1
coupman35
Northen Ontario
Now a L4060 had B2650
Looking to get a 3-Point Quick Hitch for my b2650 where can you get a good one in Ontario Canada at a good price .That fit good and works good
/ 3-Point Quick Hitch #3
Kind of depends on what you want. You can get the frame type or you can get the quick hitch adapter latches for your three point arms. These work on any width equipment. Investigate Pat's Quick Hitch.
/ 3-Point Quick Hitch #5
I own a BX2380 and added a Speeco Quick Hitch a few months ago. I purchased it from Princess Auto. It is also available from TSC. As was already said wait for a sale and get $100 or so dollars off. I am very happy with mine and it saves a lot of man handling and playing with the adjusters for some attachments.
The quick hitch comes with one set of bushings. You will have to buy a set for each attachment you want to use with the quick hitch.
Yep saw the one at Princess Auto and TSC hope they come on special then ill get one then
Here a price I got from Kubota dealer Total After Trades $715.00 GST/HST $92.95 total 807.95 and from John Deer dealer Our 3 point hitches that we sell are $517.11
Not am looking at TSC
/ 3-Point Quick Hitch #8
I've had a pile of cheap QHes. Harbor Freight, Speedo & some I forget. They have all been decent & similar quality. Most ran off with old machines or went to friends. None broke or wore out. All needed a top hook extension & most had the top link bolts replaced with pins.
/ 3-Point Quick Hitch #9
Mine is the speeco QH from PA. I have no problems with how it works but one gotcha you have to be aware of is it doesnt fit everything and be careful with your PTO shafts making contact with the QH. The QH pushes your attachments out about 6 inches so you need a longer PTO shaft...the added length now increases the chance of contact between the QH and PTO shaft.
I had to modify mine to make it about 1 inch wider to fit most of my attachments. I also had to make a notch cut out to minimize PTO shaft interference for my mower.
/ 3-Point Quick Hitch #10
I had to modify a few impliments for mine over the years. I'd say modifying the standard QH to fit non-standard impliments is the wrong way to go. Modifying the non-standard impliments is going to be the better longterm solution.
I love the QH on the Ls I've had. The extra length & associated capacity decreases may be harder to swallow on a B or BX. I've had a few PTO shafts rub on the QH. The PHD I modified to fit on my QH (required a hydraulic toplink) had the shaft bent several inches several times.
/ 3-Point Quick Hitch #11
I the QH on the Ls I've had. The extra length & associated capacity decreases may be harder to swallow on a B or BX. I've had a few PTO shafts rub on the QH. The PHD I modified to fit on my QH (required a hydraulic toplink) had the shaft bent several inches several times.
I thought it was easier to make the cheap QH wider than making a rototiller, mower and snowblower narrower!
Well my quick hitch is order from amazon 350.00$ plus tax 395.00$. Now where to get extra set of bushings at a good deal .Where did you guy get them
/ 3-Point Quick Hitch #14
I buy mine at a local Rural King store, I found this on a google search
quick hitch bushings - Google Search
You don't need those bushings with the knob on the end. The simple, cheap category adapter bushings work just as well.
Your hook won't fall off the end because the other hook will hit the implement.
Bruce
Where do you get them cheap adapter bushing from .
20ft Shipping Container (A61166)
20ft Shipping...
UNKNOWN  20 FLATBED GOOSENECK (A58216)
UNKNOWN 20...
2015 Hustler Raptor Zero Turn (A63116)
2015 Hustler...
New/Unused Landhonor Adjustable Gantry Crane (A61166)
New/Unused...
2016 Kubota SVL 95-2S Skid Steer (A61166)
2016 Kubota SVL...
1995 Crosley 20ft. 3 Ton T/A Equipment Trailer (A61568)
1995 Crosley 20ft...
