3 point quick hitch on a BX?
   / 3 point quick hitch on a BX? #11
My OEM BX ballast box fits with pats, did they change the design of the ballast box for them to not fit?
See my pictures above.
My ballast box was purchased with my BX in 2010. It is an OEM Kubota box.
Wrooster
   / 3 point quick hitch on a BX? #12
Wrooster
So did I in 2010 and mine looks completely different. I wander if they made two versions.
   / 3 point quick hitch on a BX? #13
Ahhh, OK, that is the B5320 ballast box from the prior BXxx20 series models.
The current ballast box for the BXxx60 series is the B8160, which is in fact designed for use with either the BX or B series tractors. And, the label on the side of my box specs the ballast weight for both of these models, 300 lbs and 500 lbs, respectively.
Wrooster
   / 3 point quick hitch on a BX? #14
Wrooster
All I can say is yours looks way cooler and I like the fact yours have feet to keep off of the ground, my bottom is showing a lot of wear from sitting on the ground.
   / 3 point quick hitch on a BX? #15
All I can say is that yours is compatible with Pat's system. :thumbsup:
Wrooster
2014 GMC ACADIA SUV (A51222)
2014 GMC ACADIA...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2025 JMR 40in Single Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A50322)
2025 JMR 40in...
2016 Ford Explorer...
2017 DITCH WITCH RT30 (A51243)
2017 DITCH WITCH...
Parker 400 bu Gravity Wagon (A50515)
Parker 400 bu...
