3 Point PTO Post Hole Digger Attachment w/ Auger
   / 3 Point PTO Post Hole Digger Attachment w/ Auger #2
I have a county line, Tractor Supply carries this brand. Very satisfied with it and they're less expensive too if you have a TSC close around
I made a frame to hang it from, makes it so much easier to put on and take off
   / 3 Point PTO Post Hole Digger Attachment w/ Auger #3
I dont have that one but when you do get one you should check your gearbox oil alot of them are shipped dry .
   / 3 Point PTO Post Hole Digger Attachment w/ Auger #4
I have the same on from Tractor Supply Store. I purchased the 6" and 9" auger bits. You do have to buy 80-90w oil as the box is dry.
   / 3 Point PTO Post Hole Digger Attachment w/ Auger #5
I had a 6" and 9" already, when I bought this one used, it came with a 9" and 12" I haven't taken the 12" off since I put it on! although we're going to be planting some shrubs early spring that might not need such a big hole
   / 3 Point PTO Post Hole Digger Attachment w/ Auger #6
Let us know how the drilling goes for you. We have the same tractor for the most part. My 6" dug and killed the motor a couple of times. I still have to use the 9" for concrete posts for our wood deck we are building for our koi pond. I will do a couple of videos on that progress when we start. I hear the smaller the auger bit, the easier it is to get stuck and drill in instead of cutting and pulling soil out.
   / 3 Point PTO Post Hole Digger Attachment w/ Auger #7
I have a 'dirty hand tools' PHD with the 9" auger. Works great.
Thanks folks, I do have a TS store...and I think Dirty Hands is Loews, correct?
   / 3 Point PTO Post Hole Digger Attachment w/ Auger #9
I bought an EA PHD with a 9" and 12" auger. So far it works great. Make sure you by extra shear pins. The 3rd hole I dug, I sheared the pin and got the auger stuck. I used a pipe wrench and cheater bar to unscrew the auger a bit before I could lift it out.
EA 6900 Heavy Duty Tractor Post Hole Digger
The picture on the EA website is a picture of my tractor.
   / 3 Point PTO Post Hole Digger Attachment w/ Auger #10
Dirty hand tools are their own, but lowes does distribute them. TSC also carries them. I got mine through the LS dealer, that's the line that he sells.
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
2015 Ford Transit 150 Cargo Van (A55788)
2015 Ford Transit...
Decorative Bear Statue (A55758)
Decorative Bear...
2015 Mitsubishi Outlander Sport SUV (A55758)
2015 Mitsubishi...
40' High Cube Multidoor Container (A53316)
40' High Cube...
2013 Ford F-150 (A53422)
2013 Ford F-150...
