3-Point Pallet Mover
/ 3-Point Pallet Mover #1
WVBartMan
West Virginia
Kubota L5030, M9540
Anyone familiar with companies who manufacturer a pallet mover that fits a 3-point hitch (3,000 lbs capacity)? If there on the internet, a website address would be greatly appreciated, thanks.
Mayhem: Fertilizer on 2,000 lb pallets. I will probably put it on a Kubota L5030.
/ 3-Point Pallet Mover #6
Looks like he's getting ready to move the house. /forums/images/graemlins/grin.gif
/ 3-Point Pallet Mover #9
a guy on ebay sells boxed forks and forged ones that can lift 3k i believe, for under 500.
/ 3-Point Pallet Mover #10
heres a set i made for the back of my ford 8000, i used forks and carraige from a junk forklift, i have moved cars around with them with a set of extensions on them, they handle alot more than 3000 lbs, i think your best bet is to make or have someone make a setup like this
Markct: I believe what you have is what I'm looking for. I will start looking in the junk yard for a set of forks. Thanks for the help.
By the way, how do you include a picture in your response?
/ 3-Point Pallet Mover #13
i bought a set of forks from a forklift repair/sales shop. they had 30 or so sets for me to choose from.
/ 3-Point Pallet Mover #14
wvbartman, where ya from, it doesnt say on your profile, if your nearby i may be able to build a simular set, altho there realy not that hard to make if you have a large drill press or milling machine and a welder, i actualy bored the holes on our horizontal milling machine since our drill press is a bit light for heavy drilling. the forks have held up great tho to all the abuse my tractor could dish out, i often use fork extensions made from 8 inch channel that are around 8ft long to move larger stuff like sheds, and last weekend i used them to move a slide in truck camper, that realy made the front end light but the forks held up fine, i use them with my homemade hyd toplink usualy which is a huge help, makes it easier to get under stuff and to dump stuff off the forks
Pekabu: How much did they charge you for a set of forks?
/ 3-Point Pallet Mover #16
WVBartman -
Here's a nice site (seeing as you have a *nicely sized* tractor):
Attachments International
Maybe also:
Carver Equipment
Last - but certainly not least - try:
Markham Welding
Lots of folks here rave about Markhams' toothbars - I'm inclined to getting one from them too - if I don't build one myself.
I also picked up some used forks and welded up a 3PH frame:
Bigger Pic
I'm no expert welder - but my 3PH can only lift @ 1000 lbs - so I'm very confident about its strength up to that range. I'd have to be a bit more practiced until I felt comfortable with one for a 2000 lb capacity.
Hope one of those links helps,
Dan
SET OF (4) PORT A POTTIES (A65643)
SET OF (4) PORT A...
2019 FREIGHTLINER M2 4X2 S/A NON 26FT NON CDL BOX TRUCK (A59914)
2019 FREIGHTLINER...
2006 Ford E-350 Passenger Van (A64194)
2006 Ford E-350...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
20ft Shipping Container (A65579)
20ft Shipping...
2022 Great Plains 3000TM Turbo Max VT (A66285)
2022 Great Plains...
