3 point not working
/ 3 point not working #1
Mr Bitz
North Dakota
Branson
Hi all. I have a 2012 bobcat CT 235 and my 3 point is not working, I've messed with the knob under the seat several times ,pulled the valve assembly out, cleaned it, found nothing unusual, put back together still nothing, doesn't even try or anything, 3 point just stays down, nothing happens, have good flow to the valve, everything else works just fine,including the loader and hydro. Only thing we did to it was service everything out including the hydraulic system, engine, and all filters. Anyone have any ideas? We even tried to pull the valve that's connected to the turn knob out and run it that way. When we do this the 3 point comes up but there is no control to it and you can physically push it down with your hands and it'll come back up. Anyone have any ideas? I'm at a loss. A new 3 point valve assembly is $1000. Might have to try that if there is nothing else.. But I am not convinced that that's the problem.
/ 3 point not working #2
I dont know much of anything about hydraulic troubleshooting, but how many times have you cycled your loader up and down since the fluid/filter change? May need to cycle it several times to purge?? system, cause it sounds like you could have air or debris in the 3 point, just a thought.
/ 3 point not working #3
Rockshaft cylinder seal may have failed or main relief valve stuck open.
/ 3 point not working #4
Since this tractor is a Kioti, on the hydraulic block that provides flow to the loader valve, there is a small spool. Here is a page from the manual to explain it better:
Maybe this can help you.
/ 3 point not working #5
Do you have any remotes on the tractor? If one of the remote levers is not centered in neutral position the 3 pt will not operate.
/ 3 point not working #7
Mr. Bitz?.......Have you solved your problem?
Please report back so others can learn from your experience.
Yes it was the control valve. Installed a new one for $1000 and we're good to go.
2026 Quality steel dump truck (A56859)
2026 Quality steel...
1998 POLAR TANK (A60736)
1998 POLAR TANK...
2004 INTERNATIONAL 7400 20FT TANDEM AXLE FLAT BED (A59906)
2004 INTERNATIONAL...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
KJ K4525 45'x25' Double Garage Barn Shed (A60463)
KJ K4525 45'x25'...
2018 Chevrolet Equinox AWD SUV (A59231)
2018 Chevrolet...
