3-Point Log Splitter
   / 3-Point Log Splitter #1
rgarza348
I have a Kubota BX2230 and looking for a log splitter and considering a 3-point log splitter attachment. I found a 15-ton splitter on the Gearmore website - Model LS20E. I'd like some feedback if anyone has experience with this splitter and how it might work on a sub-compact tractor. My biggest concern is the hydraulic pump output on the tractor is 5.5 gpm, but the log splitter manual recommends 8-15 gpm at 1500-2500 PSI.
   / 3-Point Log Splitter #2
Then why are you even considering it in the first place? It's simply not enough tractor. I don't believe you'll find a 4" splitter for a tractor that small. You should consider dropping down to a 3". Here's a possibility: Amazon.com: Powerhorse Horizontal Log Splitter - 3 Pt., 13-Ton Ram Force, 3in. x 18in. Cylinder: Home Improvement
//greg//
   / 3-Point Log Splitter #3
Welcome to TBN:D
The splitter will work, but it will be SLOW. There are MANY post's here on TBN about 3PH splitters and the positives/negatives of them if you search a little.
2015 Ford Fusion Sedan (A59231)
2015 Ford Fusion...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
2018 CATERPILLAR 326FL EXCAVATOR (A60429)
2018 CATERPILLAR...
gps trailers (A56859)
SHOP BUILT TOOL TRAILER (A58214)
SHOP BUILT TOOL...
