dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,803
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
I have searched the archives and not found my answer.
I just got a new Bobcat CT230, which is the same machine as my Kioti
CK30, which I have used for years.
I was testing out the new machine with a box blade, and I noticed that
the 3-pt hitch initially would raise the BB up pretty high. When I started
using it, I found that sometimes it would not rise very high at all, even with
the position control level at the top limit of its travel. Other times, it would
rise as high as I would expect. My first guess was that I was low on
hyd fluid and the intermittancy of the problem was due to the position of
the tractor on different slopes.
So I bought the tractor back to my workshop and added some fluid, though
the dipstick showed midrange full. The 3-pt would not lift more than 6-8in
off the ground! The pump made no different noise, there was no relief
valve sound, the FEL works fine. I cycled the BB up and down multiple
times, and it would not go higher. Rate-of-drop valve is fully open.
This tractor has position control, but no draft control, though DC is an
option that is described in the parts and service manuals that I have (CK30).
My suspicion is that there is an assembly problem with some linkage inside
the 3-pt cyl housing. There are two large hex caps on the right rear side
of the gearcase and one of them was not fully seated. I tightened it up.
A look in the two manuals indicates they are "pins" and seem to be part
of the draft control system. Since I do not have that option, I wonder
what these pins connect to. Has anyone on TBN had their gearcase open?
I may have to take the 3-pt cyl housing off the top of the gearcase to
fix this. Or have Bobcat come and get it. I doubt anyone at Bobcat has
tackled a problem like this, however. Not sure I want them in there,
warranty or not.
warranty or not.
