3 point lift has 5 second delay
   / 3 point lift has 5 second delay #1
Rudevette
Bronze Member
End of the road, NE South Dakota
Bobcat CT235
It's a bobcat but since it's the same as kioti here goes:
So my Bobcat Ct235 has about 150 hours on it now. It is a couple of years old. :confused2: I changed all fluids and filters at 65 hours and everything was fine. This morning I ran 3 miles down the road doing some snowplowing, a little blowing, etc. to get the road opened so my wife could get home from work. Everything worked fine. Tractor was about out of fuel so I parked it by the house and went to town to get fuel and take care of some business. When I got home 5 or 6 hours later I fueled it up and started it, jumped on it and blew snow back aways. Then when I went to lift the blower it didn't lift. It takes about 5 seconds, then I hear the pump make some whining noise and the blower lifts. It drops just fine and the drop speed adjustment knob is not the problem because it makes no difference where it's set. The rear hydraulic remote is hooked up to the chute rotator on the snowblower and it works perfectly. The loader works perfectly. All are fast and responsive. It's just the 3 point that is having a problem. Can anybody help me out here?
Thanks,
Justin
   / 3 point lift has 5 second delay #2
Thanks,
Justin
Does this model have draft control? If yes is it possible that while blowing snow a little snow got packed in around the linkage and melted from the tranny warmth. You then parked it for a few hours and froze up causing some binding. Just a guess but I have had snow freeze the throttle linkage up before.
Roy
The only draft control is the knob on by the floor that slows down the lowering speed of the 3 point. It works fine. I can get it to drop very fast to very slow and everywhere in between. I didn't see any ice frozen to anything on the trans either. (on the outside that it)
   / 3 point lift has 5 second delay #4
Sounds like something in the three point assembly is "frozen and/or binding". I would suggest a carefull scan of the lift arms and the assocciated pins/linkages. The whining would probably be the relief valve saving your pump
   / 3 point lift has 5 second delay #5
Do you or a friend have a building you could move the tractor into? Let it run for a while warm up and melt all the snow to see if you have the same problem. It could be an easy fix.
Ok. I just went out and played with it. Once I pull the lever to lift it takes between 16 and 18 seconds to lift. The noise it makes is the engine starting to take some load as it goes up. It does not whine like a hydraulic bypass valve bypassing. There is no snow or ice anywhere on it. I will try sticking it in the garage as a last ditch effort
   / 3 point lift has 5 second delay #7
It's a bobcat but since it's the same as kioti here goes:<snip>Bobcat Ct235 has about 150 hours on it now. It is a couple of years old. :confused2: I changed all fluids and filters at 65 hours and everything was fine. This morning I ran 3 miles down the road doing some snowplowing, a little blowing, etc. to get the road opened so my wife could get home from work. Everything worked fine. Tractor was about out of fuel so I parked it by the house and went to town to get fuel and take care of some business. When I got home 5 or 6 hours later I fueled it up and started it, jumped on it and blew snow back aways. Then when I went to lift the blower it didn't lift. It takes about 5 seconds, then I hear the pump make some whining noise and the blower lifts. It drops just fine and the drop speed adjustment knob is not the problem because it makes no difference where it's set. The rear hydraulic remote is hooked up to the chute rotator on the snowblower and it works perfectly. Do you have an A/B lever for your remotes that might be in the wrong position? Have you verified hydraulic fluid level recently? The loader works perfectly. All are fast and responsive. It's just the 3 point that is having a problem. Can anybody help me out here?
Thanks,
Justin
Please see questions above in blue.
Thanks, CM
Fluid level is good and I only have one set of remotes and the control lever is in the neutral position. If it was stuck in either detent the chute rotator would be stuck all the way one wy or the other.
   / 3 point lift has 5 second delay #9
Could have piece of trash in MLS valve. This is the valve under seat that controls drop rate of 3 point hitch. Slim chance but possible. Before that check all your hydraulic lines, you could be sucking air in somewhere causing this problem. Check fill cap on rear and make sure air will pass through. Thats it without looking at it myself.
Tony
   / 3 point lift has 5 second delay #10
Yes I saw you say it couldn't be "drop valve" but it can. Oil has to flow through it.
Toro Workman Utility Cart (A51694)
Toro Workman...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
2007 Nissan Armada Multipurpose Vehicle (MPV) (A51694)
2007 Nissan Armada...
2010 Ford Fusion Passenger Car (A51694)
2010 Ford Fusion...
2018 MDB LV600 GREEN CLIMBER SLOPE MOWER (A51406)
2018 MDB LV600...
