3-point hydraulic unit lifting force
   / 3-point hydraulic unit lifting force #1
oosik
Epic Contributor
AMBER, WA
2009 Kubota M6040
I have a question for wiser minds. I'm wondering how to figure what my 3-point unit will lift. My tractor is a Kubota M6040 and is rated at 4200 lbs lifting force at the lifting point(end of the 3-point arms) & 3300 lbs at a point 24" back of the lifting point. Very few implements, that I'm aware of, have 100% of their weight right at the lifting point(exact end of the 3-point arms).
So how do you figure if the 3-point is rated to lift an implement. As an example - a brush hog that extends six feet behind the lifting point and weighs 1200#. Where is the "lifting point" on this brush hog. I wouldn't think its right at the point of connection to the 3-point arms.
I can, more or less, extrapolate the lifting force out beyond the end of the 3-point arms but need a general idea of where the lifting point is figured on any implement.
I wonder if you would consider the lifting point on any implement as its center of mass/balance point. It is time for wiser minds to explain this situation.
   / 3-point hydraulic unit lifting force #2
I would consider the "lifting point" to be the center of mass for the implement. In engineering calculations, the center of mass is where the entire weight of the entire object acts, and I think that equates perfectly to this situation.
Rosher18 - center of mass was kind of my thinking. But my field isn't engineering........ Thanks for your comments. Oosik
   / 3-point hydraulic unit lifting force #4
In the case of a single spindle rotary cutter, the center of mass will be close to the center of the center line of the gearbox. Maybe a couple of inches in front of it since there are probably more heavy framing on the front end.
   / 3-point hydraulic unit lifting force #6
And if you don't have your hydraulic system at "proper" pressure you may easily be missing 10% of your lift capacity.
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2018 Nissan Murano S SUV (A50324)
2018 Nissan Murano...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
2017 Rogator RG1300B Dry Fertilizer Applicator (A52128)
2017 Rogator...
2024 Isuzu NRR 24ft Box Truck (A50323)
2024 Isuzu NRR...
John Deere 2700 Mulch Ripper (A50514)
John Deere 2700...
