3-Point Hitch 3-point Hydraulic cylinder has flow by
   / 3-point Hydraulic cylinder has flow by
Yes, the drawing for the FX28D shows the parts going in from the inside of the front plate - no way, the opening from the inside in much too small. I'm assuming that Yanmar made two different lock valve assemblies for the FX28, one without the the ball & spring setup and the other with it. I notice that Hoye shows both breakout drawings for YM1500 on their web site (image below) . So, I pushed the valve (no.9) in from the front, small end first. Well, I put the box blade on the 3-point and it raises and lowers. But, the lift arms still have a small drop and jump motion, indicating fluid loss somewhere. The lock valve in closed position will freeze the lift arms, but they slowly drift back down (about 4 minutes). I slightly scored the end of the no. 9 valve which may be causing the problem, or the piston seal is not working. I may just have to live with it.
   / 3-point Hydraulic cylinder has flow by #52
Yes, your leak down could be coming from the control valve or a relief valve. Could be trash in one of them or possible bad o-ring in one of them.
   / 3-point Hydraulic cylinder has flow by #53
Or like in my case just wear. I replaced everything I could O ring wise in my 3pt valve and it will still slowly leak down after I put the new O ring on the piston and the o rings in the valve.
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
2014 PETERBILT 579 MID-ROOF SLEEPER (A58214)
2014 PETERBILT 579...
2009 Sterling Derrick Digger Truck (A55973)
2009 Sterling...
2009 INTERNATIONAL DURASTAR 4300 SBA ROAD TRACTOR (A58375)
2009 INTERNATIONAL...
2005 John Deere 330CL (A55272)
2005 John Deere...
