3-Point Hitch 3 point hitch
   / 3 point hitch #1
XXL
I have a RU1400 Iseki tractor. I bent the lower link pivot shaft on the 3 point hitch assembly. The shaft is 14.5 inches long and .855 inch diameter, with a 3/16 inch hole near each end. It appears to be made with cold roll steel. Does anyone know of a source for this shaft? Thanks for your help.
   / 3 point hitch #2
I would go to a bone yard and get an axle off of something that mic'ed out to .855 or 21 millimeters, cut it and weld it in. The hole is for the hitch pin I presume?
Seems like the axle would be heat treated and harder than what you have now. Might be hard to drill a hole in. You could cut the hole off and weld it on the end. that would be custom!
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
HYSTER H60XT FORKLIFT (A52472)
HYSTER H60XT...
Case IH Farmall 75C (A52349)
Case IH Farmall...
Has Charger with it. (A51694)
Has Charger with...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
