3 point hitch
/ 3 point hitch #1
hernando
tennessee
dk 4510 kioti and a 450 case track loader
I have a dk4510 ,, great tractor ,,the 3 point started jumping ,,,not bad but just like it will leak down a bit then catch up and raise ,,,this is all when it is running if you shut it of it will leak all the way to the ground....any ideas ?? Thanks for any help
/ 3 point hitch #2
After you put the hitch at the desired height,turn the lowering speed valve closed. See if it still leaks down , also make sure your hydro fluid at correct level (filled correctly) . Could be some internal valve ? My post will also bumped you back up others with more mechanical skills or familiar with your Yote i'am sure will respond with there ideas .
/ 3 point hitch
I did try that and it still leaked down ,,,fluid is correct maybe a very little over full.....it is under warranty I might have to take to the dealer ,,I was hoping for a easy fix ,,,I use it every day....cant be without a tractor thanks for the reply
/ 3 point hitch
any ideas on something I can check myself ???? thanks
/ 3 point hitch #5
Sounds like warranty time. If it leaks down with the lowering-speed valve closed I'd suspect the piston seal is leaking or the MLS valve (or associated seals) is defective. Not something you'd want to DIY of you can get the dealer to do it free.
By the way. all these leak down but slowly (hours or days).
/ 3 point hitch #6
Call your dealer and talk with the service manager. The might come and pick it up or fix it there. If they pick it up and you cant do without ask for a loaner tractor while yours is being repaired.
NEW IDEA 323 - 1R CORN PICKER (A64277)
NEW IDEA 323 - 1R...
Location Tampa, FL (A61567)
Location Tampa, FL...
2007 Ford F-450 Flatbed Truck, VIN # 1FDXF46P77EA72394 (A65563)
2007 Ford F-450...
New/Unused Pallet of Webbing Slings (A65583)
New/Unused Pallet...
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
John Deere 7230 (A62180)
John Deere 7230...
