3 point hitch
/ 3 point hitch #1
micman32
Millersburg, Ohio
Yanmar 221/Cub Cadet XT2
Have a Yanmar 221 with a quick hitch. When I use my Landpride Brush hog it will not lift the tail wheel end off the ground. I am sure it's not set up right. Just wondering what anyone thinks and advise.
/ 3 point hitch #2
If the cutter is coming off the ground at the three point hitch, you may just need to shorten the top link some. In the down position, while mowing, you want the tail wheel touching and the bottom of the brush hog not touching.
/ 3 point hitch
Problem solved! The A frame on the cutter needed to be moved to the lower set of holes. Landpride had a note the manual about this.
2015 Ford F-250 Knapheide Service Truck (A64556)
2015 Ford F-250...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
