3 point hitch
   / 3 point hitch #1
chuck172
Platinum Member
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
My new dk makes hitching up implements so easy with the telescoping lower links, and the rear pto remote lift that I don't even use the quick attach anymore.
   / 3 point hitch #3
It looks like a lever that you can grab from behind the tractor to raise/lower the lift arms.
From Kioti's website:
Allows operator to control the 3-point hitch from the ground at the rear of the tractor. Attaching implements is easier and safer with this control within easy reach.
   / 3 point hitch #4
I used a 3' piece of PVC tube with a 90 degree elbow to raise/lower the lift arms and extend/retract the hydraulic top link, back when I had a tractor.
There have been some threads on here about making the linkage to do that.
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
2015 Nissan Pathfinder SV SUV (A50324)
2015 Nissan...
Veshai PWS-100 2,200lb Electric Pallet Jack (A50322)
Veshai PWS-100...
2012 Ford F-450 Altec AT200A 30ft Bucket Truck (A50323)
2012 Ford F-450...
Unused 2025 CFG MH12RX Mini Excavator (A50322)
Unused 2025 CFG...
2010 Toro Z Master 2000 52in. Zero Turn Commercial Mower (A50322)
2010 Toro Z Master...
