3 Point Hitch Won't Pick Up
   / 3 Point Hitch Won't Pick Up #1
BobbyCarmon
Greenville,NC
TO30 and 384 International
I have a TO30 1954 massey ferguson, the lift is not working. It sounds like the same problem that (dscearce posted on 9/23/12). I've read the replies from his post. Is the TO30 hydraulic system the same as the 165? and can I use these replies to maybe solve my problem?
Thanks, you all for your help
   / 3 Point Hitch Won't Pick Up #2
first, have you checked the oil level?
start off by telling us some details.
what have you done or not done yet?
was it working then stopped, or is this a new purchase? or?
   / 3 Point Hitch Won't Pick Up #3
Is your pump turning?
Is the hyd tank full?
Is the 3pt lever working correctly?
Install a hyd gage and check some pressures.
Is the descent/lower valve locked down?
Is the lift moving a little or not at all?
Are the filters and screens good and clean?
Checked the oil level--Good, showing full
That's all I've done so far.
Thought I'll check the posts out first to see if someone else has had or are having the problem
What do I need to look for to tell if the pump is turning (I'am green)
The 3pt lever is working correctly
the lift is not moving at all
Don't have a hyd gage to check, Will get one
Will check filter and screens and clean if needed
Thanks
   / 3 Point Hitch Won't Pick Up #5
check my post again and get back with more details.
   / 3 Point Hitch Won't Pick Up #6
You could loosen or remove a hose and place in a bucket and check for fluid. Be careful and only run the engine for a brief check.
   / 3 Point Hitch Won't Pick Up #8
1965 Ford 4000 Tractor - I'm trying to repair my three point hitch. Took off the top cover and removed the lift cylinder is this suppose to move a little The service manual i have does not have any good pictures of how this part is suppose to work.
Thank you for any assistance
TydeFarm
   / 3 Point Hitch Won't Pick Up #9
is this suposed to move a lil?
can you ben any more clear in your question?
does what move?
the cyl?
the piston?
   / 3 Point Hitch Won't Pick Up #10
The Hydraulic Lift Cylinder (Part number C5NN477B) inside the lift cylinder appears to be a moveable sleeve or maybe its just a lip that is welded to the lift cylinder and it only looks like a sleeve. If its a moveable sleeve inside the lift cylinder then my problem is that the sleeve is rusted from the inside to the lift cylinder and I need to free the sleeve. I think what I see as a lip inside the lift cylinder is really welded to the lift cylinder and does not move.
Thank you
2011 CIRCLE M 32 FOOT GOOSENECK (A53843)
2011 CIRCLE M 32...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55301)
2023 NEW HOLLAND...
2005 TerraGator 8104 (A55301)
2005 TerraGator...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
