3 Point Hitch Won't Pick Up
   / 3 Point Hitch Won't Pick Up #1
BobbyCarmon
Greenville,NC
TO30 and 384 International
I have a TO30 1954 massey ferguson, the lift is not working. It sounds like the same problem that (dscearce posted on 9/23/12). I've read the replies from his post. Is the TO30 hydraulic system the same as the 165? and can I use these replies to maybe solve my problem?
Thanks, you all for your help
   / 3 Point Hitch Won't Pick Up #2
first, have you checked the oil level?
start off by telling us some details.
what have you done or not done yet?
was it working then stopped, or is this a new purchase? or?
   / 3 Point Hitch Won't Pick Up #3
Is your pump turning?
Is the hyd tank full?
Is the 3pt lever working correctly?
Install a hyd gage and check some pressures.
Is the descent/lower valve locked down?
Is the lift moving a little or not at all?
Are the filters and screens good and clean?
Checked the oil level--Good, showing full
That's all I've done so far.
Thought I'll check the posts out first to see if someone else has had or are having the problem
What do I need to look for to tell if the pump is turning (I'am green)
The 3pt lever is working correctly
the lift is not moving at all
Don't have a hyd gage to check, Will get one
Will check filter and screens and clean if needed
   / 3 Point Hitch Won't Pick Up #5
check my post again and get back with more details.
   / 3 Point Hitch Won't Pick Up #6
You could loosen or remove a hose and place in a bucket and check for fluid. Be careful and only run the engine for a brief check.
   / 3 Point Hitch Won't Pick Up #8
1965 Ford 4000 Tractor - I'm trying to repair my three point hitch. Took off the top cover and removed the lift cylinder is this suppose to move a little The service manual i have does not have any good pictures of how this part is suppose to work.
Thank you for any assistance
TydeFarm
   / 3 Point Hitch Won't Pick Up #9
is this suposed to move a lil?
can you ben any more clear in your question?
does what move?
the cyl?
the piston?
   / 3 Point Hitch Won't Pick Up #10
The Hydraulic Lift Cylinder (Part number C5NN477B) inside the lift cylinder appears to be a moveable sleeve or maybe its just a lip that is welded to the lift cylinder and it only looks like a sleeve. If its a moveable sleeve inside the lift cylinder then my problem is that the sleeve is rusted from the inside to the lift cylinder and I need to free the sleeve. I think what I see as a lip inside the lift cylinder is really welded to the lift cylinder and does not move.
Thank you
2019 FORD F-150 XL TRUCK (A51406)
2019 FORD F-150 XL...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
Bale Spear - Fits John Deere 300/400/500 Series Carrier (A55218)
Bale Spear - Fits...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2007 CHEVROLET C4500 DUMP TRUCK (A51406)
2007 CHEVROLET...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2021 Allmand Bros...
