3-Point Hitch 3 point hitch won't go down
   / 3 point hitch won't go down #11
Disregard, I am an idiot, I knew about the knob, but since i set the knob a year ago when I bought the tractor, I have not messed with it. It turned out I must have hit the knob. When I woke up this morning the first thing i checked was the knob and it was all the way to the "turtle." Works fine as always!! However, I am bringing the tractor back to the dealer in the morning because I have had a small leak on the hydraulic hose that ties into the steering cylinder. It has leaked since i bought it new, but it has only been enough to keep it wet and not leak too much. I fugure I might as well have the dealer repair it while its under warranty. Thanks for the feedback though!!
The best repairs are ones that are not repairs. Good news.
   / 3 point hitch won't go down #12
Hydraulic cylinder, inside the housing on top of the rear axle.
   / 3 point hitch won't go down #13
Check and see if you inadvertently hit the 3PH speed control valve and spun it shut. I have done this on 2 different tractors it is usually a knob below the seat in front.
TBN saves the day again! I never touch it but guess it got turned somehow.
   / 3 point hitch won't go down #14
You bump it with your foot getting on and off the tractor.. I have done it several times
   / 3 point hitch won't go down #17
Another save for me--just had the same "issue"
It is a good feeling when it turns out to be a no cost "fix" isn't it:)
   / 3 point hitch won't go down #18
Glad to find this thread. The knob had me frozen in the up position. I hadn't moved it so I didn't think about it being the issue, and I had forgotten it was there - and it was dark and raining. But thanks to those who mentioned that it can inadvertently be changed by a foot - or in my case maybe a 6-year old grandson. Half a twist and the box-blade began to slowly settle.
Bob
   / 3 point hitch won't go down #19
Bob
We see dozens of these types of posts each year here on TBN. It is just part of tractor ownership. :thumbsup:
   / 3 point hitch won't go down #20
I have a Shibaura with all japanese control markings. This thread has been another in a long line of revelations.
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
500BBL SKIDDED FRAC TANK (A55745)
500BBL SKIDDED...
2011 FORD F-250 Crew Cab 4X4 Pickup Truck (A53422)
2011 FORD F-250...
2018 Ford Explorer AWD SUV (A53424)
2018 Ford Explorer...
