3 point hitch rake
/ 3 point hitch rake #1
lilranch2001
Super Member
Bobcat CT 235
My driveway is almost a thousand foot long, 4000 square foot barnyard, all in crushed limestone
Since buying my tractor I have been working to get my driveway back into shape after 10 years of neglect.
In the process I have worked up a lot of #3's (what they call 3-4 inch limestone in our area)
I need to apply 3-4 inches of 73's (<3/4inch with fines) next spring, but I want to get the worked up #3 out of the mix so they dont work back up again.
If I can rake them into a pile I have a good place for them, and can move them with my FEL.
Now my question, how good does a rake work, and are they worth purchasing one?
I have raked them all up (with a garden rake) a couple of times, and that is getting old
I see a lot of you with one, I have just never used one and wonder if they are worth having
Any opinions will be appreciated
/ 3 point hitch rake #2
I have a 5 foot rake from TSC. I have used it to rake and level dirt. Also works good on small limbs. I have never tried to rake rock with it but it should work. I ended up taking out every other tine on the rake as it was picking up everything.
/ 3 point hitch rake #3
I too have a TS 5' 3pt hitch rake. All the driveways i blow out or plow are all stone and dirt. I have excellent results putting back what i tore up in the winter.I rake my lawn each spring with it, down fall is pulling out the twigs from the rake teeth. Last year i put in several 3-4 acre lawns with little hand cleanup. This TS rake is about 4 years old and it was cheap to buy but . . .You need to play with it to get use to it, my rake dose almost as good as a hand rake without the time-consuming labor .. . John
/ 3 point hitch rake #4
The main use for my 5 foot rake is keeping the roads in shape. I use it to take care of about 1.5 miles of private road.
/ 3 point hitch rake #5
I use Dense Grade gravel on my 500 ft. drive and it drives like I am on blacktop. I haven't done anything to mine for ten years now. I find that there is no raking or grading needed. Dense grade is all grades from dust to 3/4" and it packs like concrete. I hope this helps.:)
(1) UNUSED 9.5-16 TIE W/ 6 LUG RIM (A64280)
(1) UNUSED 9.5-16...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
1993 CHEVROLET Corvette (A59231)
1993 CHEVROLET...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
2019 CATERPILLAR TL642D TELESCPOPIC FORKLIFT (A62129)
2019 CATERPILLAR...
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
