3-Point Hitch 3 point hitch lever hard to move
   / 3 point hitch lever hard to move #1
victor43
Upstate New York
Kubota B2400
1996 Kubota B2400 HSD 4 wheel drive, B2660 front mounted snow blower
I live in upstate NY. Got 33" of snow last night. What a workout for the Kubota. The hydraulic lift cylinder lifts the snow blower when the 3 point hitch handle is pulled all the way back. By the time I was done, the handle was getting hard to move both back and forward. What could be causing this? Is some lubrication needed? Hope there is an easy fix. Thanks
   / 3 point hitch lever hard to move #2
Did you check to make sure snow and ice didn't accumulate in that area?
   / 3 point hitch lever hard to move #3
Do you leave your tractor parked outdoors? Did you try WD40?
   / 3 point hitch lever hard to move #4
Water sometimes collects in the valve and makes it hard or impossible to use.
WD40 did the trick. Sprayed the linkage joints and now the lever moves back and forth smoothly. Thanks for the helpful ideas.
UNUSED FUTURE SF60 HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE SF60...
UNUSED JCT 72" HYD TILLER (A57193)
UNUSED JCT 72" HYD...
2015 Nissan Altima Sedan (A55853)
2015 Nissan Altima...
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A57193)
UNUSED FUTURE MINI...
2006 Toyota 7FGU60 Forklift (A55973)
2006 Toyota 7FGU60...
John Deere 2040 Utility Loader Tractor (A55851)
John Deere 2040...
