3-Point Hitch 3 point hitch lever hard to move
   / 3 point hitch lever hard to move #1
victor43
Upstate New York
Kubota B2400
1996 Kubota B2400 HSD 4 wheel drive, B2660 front mounted snow blower
I live in upstate NY. Got 33" of snow last night. What a workout for the Kubota. The hydraulic lift cylinder lifts the snow blower when the 3 point hitch handle is pulled all the way back. By the time I was done, the handle was getting hard to move both back and forward. What could be causing this? Is some lubrication needed? Hope there is an easy fix. Thanks
   / 3 point hitch lever hard to move #2
Did you check to make sure snow and ice didn't accumulate in that area?
   / 3 point hitch lever hard to move #3
Do you leave your tractor parked outdoors? Did you try WD40?
   / 3 point hitch lever hard to move #4
Water sometimes collects in the valve and makes it hard or impossible to use.
WD40 did the trick. Sprayed the linkage joints and now the lever moves back and forth smoothly. Thanks for the helpful ideas.
2015 Volkswagen Passat 1.8T SE Sedan (A50324)
2015 Volkswagen...
2001 DITCH WITCH JT1720 DIRECTIONAL DRILL (A51242)
2001 DITCH WITCH...
1999 John Deere 7810 4wd Tractor (A52128)
1999 John Deere...
UNUSED X-STAR 101" X 25' BRIDGE PLATFORM (A51243)
UNUSED X-STAR 101"...
M & M 5 Bottom Plow (A50515)
M & M 5 Bottom...
2002 International 9200i Truck (A52128)
2002 International...
