geneP
Platinum Member
- Joined
- Jun 28, 2000
- Messages
- 835
- Location
- Central Mississippi, USA
- Tractor
- Case-International 385, Kubota L5450 w/LA1150A loader
I posted a few days ago about checking out a 243 I was interested in buying. The owner returned from off-shore work and was there today to show me the operation of the tractor. I was able to run the tractor with a 6 ft. Agri-Cutter on it long enough to get everything warmed up. The tractor operated good until I parked it with the cutter in the air to check for hydraulic leak down. The 3 point leaked down about a foot in a few minutes, probably 5-10 minutes. I had also noticed that when raising the hitch slowly, it would stutter rapidly ( but not violently) a little as it raised. It seemed like I could feel the pulse each revolution of the pump. When the position lever was raised quickly the hitch raised rapidly with no problem. I've not operated MF tractors, so I'm not really sure if this is normal with them or not. My Case-IH doesn't do it, and will hold a cutter up all night.
I didn't buy the tractor today because I wanted some input from those of you experienced with the MF hydraulic system operation to give me some input on what is normal and what will possibly require repairs. It has been my experience that when hydraulics start leaking by a seal it only gets progressively worse.
Thanks to all for sharing your knowledge with me.
