3-Point Hitch 3-point hitch hydraulic failure
   / 3-point hitch hydraulic failure #1
farmette
howell nj
ms1030
I replaced the valve control for the Ag-Tech front end loader. Now the 3-point hitch will not lift. what could be the problem? Possibly an air lock in the hydraulic system? Thanks for any input. (ms1030)
   / 3-point hitch hydraulic failure #2
What brand is the tractor.
How did you plumb the hyd.
If everything is connected in series, and the pump is pumping, then the fluid is flowing somewhere.
All valves have to be in series in an open center hyd system. .
If you installed a loader valve with PB, you should have installed the PB adapter.
The hose from the PB adapter would go back to the 3pt, and the loader OUT hose would go to tank.
http://en.wikipedia.org/wiki/List_of_tractor_manufacturers
Thanks for your reply J-J. It is a Massey Ferguson 1030.
what is "pb".
i can send a photo to your e-mail
   / 3-point hitch hydraulic failure #5
what is "pb".
PB = Power Beyond, is a port and adapter that is available on some hyd valves to route the pump fluid downstream to the next valve.
The PB port is capable of high pressure, whereas the OUT port is not.
It is necessary to connect valves in series in an open center hyd system.
Hi J.J., i contacted Prince, the manufacturer, and i do need a PB sleeve. ordered it from Northern Tool. Thank you very much for your help. regards, Farmette
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
2005 Mack Vision Semi Truck (NOT RUNNING) (A50774)
2005 Mack Vision...
2006 CIMC SZJ9341TJZ03 20FT CHASSIS TRAILER (A52141)
2006 CIMC...
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
Whiteman 6' Ride On Concrete Trowel (A47384)
Whiteman 6' Ride...
