3 point hitch has many uses
   / 3 point hitch has many uses #1
Barnboy
Decatur IL
Kubota B3030
I have used my 3 point hitch to remove fence post, concrete pillars, move decks and a small tool shed. The wife wants a paver patio with a sitting wall so the boys and i had to remove the old deck. Once i had the deck out i had to get the Sono tubes filled with concrete out of the ground. The tractor didn't struggle one bit. The tractor sure makes life easy. Attached are some photo's .
   / 3 point hitch has many uses #3
I love my diesel wheelbarrow. That's the main use for my tractor with FEL. I use the brush hog as a carrying base for stuff, too.
When using a chain like that, give lots of thought to where it will whip if it breaks or slips off. If I were working with a chain on the back of the tractor, I'd want a piece of plywood attached between the ROPS uprights. Cut a slit at eye level to look through.
Ralph
2011 TROXELL 140BBL TRIAXLE VACUUM TRAILER (A50854)
2011 TROXELL...
2017 Mercedes-Benz C300 Sedan (A48082)
2017 Mercedes-Benz...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A50397)
2024 BCL...
2015 MACK GU713 (A50854)
2015 MACK GU713...
Auger with Extension (A50860)
Auger with...
Excavator Bucket (A50860)
Excavator Bucket...
