3 point hitch fertilizer spreader modification?
   / 3 point hitch fertilizer spreader modification? #2
Haven't done this conversion, but looking at it , would say it shouldn't be to hard, and would be well worth the effort when completed.
   / 3 point hitch fertilizer spreader modification? #3
I have never seen a fertilizer spreader with an articulating arm like that, pretty weird.
Unless you are using something like a BX OR you hydraulic 3 PH doesn't work, I wouldn't think you would need a trailer to hold up the spreader. Most of those hold about 500-700 pounds of material and just about any CUT will pick up that much weight without a problem. Otherwise, you don't have to fill it to the top either if your tractor is so small that it wont carry a full hopper, just fill it 1/2 full.
   / 3 point hitch fertilizer spreader modification? #4
herd makes a trailer kit for there seeder, (not low cost) but this PDF has some pictures of it in it, http://www.edneyco.com/assets/files/manufacturers/herd/brochures/Herd Broadcast Seeders.pdf I have considered just making a trailer for mine as I think it would be much easer to hook up, and to use normally, a longer PTO shaft would most likely be needed,
If I was gong to keep the three point and just use "helper wheels" I would caster them as not to tear things up, you can see in the video the side slide of the wheel when turning sharp, and the more weight on them the more damage would or could be done,
Found another unit that was basically a three point unit that had been factory trailered so it could be ground driven,
   / 3 point hitch fertilizer spreader modification? #5
Converting to a full trailing type as suggested by BHD appears to be a far better option ,apart from the PTO shaft it would not involve a great deal more work. Would be much more convenient to use than a 3pl set up.
   / 3 point hitch fertilizer spreader modification? #6
I have that same spreader without the wheels
   / 3 point hitch fertilizer spreader modification? #7
Look carefully and you will note that the trailer wheels have a differential in the center that spins the spreader 'table'.
That style could be built from any automobile rear drive differential.
That style has no need for a PTO and could easily be home made with any old car differential.
   / 3 point hitch fertilizer spreader modification? #8
Now there's an idea.:thumbsup:
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
Ford F-350 Service Truck (A51692)
Ford F-350 Service...
2007 Ford Taurus SE Sedan (A51694)
2007 Ford Taurus...
2005 Manac AAF-48 50 Ton Flatbed Equipment Trailer (A51692)
2005 Manac AAF-48...
