3 point hitch disc mower
   / 3 point hitch disc mower #1
arksdad
PA
IH656 - NH T2310 - Country Clipper 60" ZTR
looking to purchase a 3ph disc mower. Anyone have any experience with a certain brand? Likes or dislikes.
   / 3 point hitch disc mower #2
Had a 7 ft. Lely several years ago and it did a good job. I like the models with a drive shaft better than multiple gears down the cutting arm. Several neighbors had issues with all the gears when the units got a little wear on them.
   / 3 point hitch disc mower #3
I've run a New Holland HM235 for 5 seasons now, 5 disk, 6' 8" cut. Runs on 42 PTO HP easy.
Oil is changed in cutter bar and gear box every year and blades are flipped/replaced each season.
Works great, I'm happy with it.
The 234/235/236 are economy mowers, so not sure on your usage, but "economy" suited us fine on price.
   / 3 point hitch disc mower #4
Around here, Kuhn is king of the hay mowers. I have a Kuhn GMD600 Gen II, HD that's 5 years old and a JD 265 (also a Kuhn GMD600 with green paint) that's probably 12-14 years old. (don't know exactly, I bought it used)
About the only maintenance that I do is to change the gear oil in the box and bar. The older mower, my JD 265, needed the plastic pivot bushings changed a couple years ago. That's it so far.
I usually cut my entire 52 acres before I flip or change the blades. And, even then, it's more for my convenience. I could cut longer before changing, but it would be right in the middle of my cutting.
Just a tip, but you might want to post this in the HAYING section.
   / 3 point hitch disc mower #5
I also have a Kuhn. Gmd600hd " I think "7'10" cut. It may not be the best, but I sure do like it. It is set up with a system were once you lower the 3 pt hitch the hydraulic cylinder will raise and lower the cutter off the ground for making turns.
I have used other brands and much prefer the operation , not having to lift the 3 pt every time I make a turn. Just make sure what ever mower you choose take the time to set it up properly. Makes all the difference in the world, a great mower not set up well will cause serious head aches.
Good luck and have fun shopping
   / 3 point hitch disc mower #6
I spent 10 minutes spacing and punctuating for the grammar police and it still didn't help.
Sorry ( not really )
   / 3 point hitch disc mower #7
Best advice right there, correct hitch geometry and settings make mowing a pleasure versus a pain. Follow the book a guideline then adjust to suit tractor.
1993 Ford F700 Stakebody Flatbed Truck (A51691)
1993 Ford F700...
2016 Chevrolet Silverado 3500HD Knapheide Service Truck (A51692)
2016 Chevrolet...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A53426)
2018 UTILITY VS2RA...
2018 Link-Belt LBX 300X4 Hydraulic Excavator - Aux Hydraulics - 6388 Hours Showing - 24 In Bucket (A53473)
2018 Link-Belt LBX...
2022 Ford Explorer SUV (A51694)
2022 Ford Explorer...
2012 Freightliner M2 106 Braun Ambulance (A51692)
2012 Freightliner...
