3 point hitch disc mower
   / 3 point hitch disc mower #1
arksdad
Bronze Member
PA
IH656 - NH T2310 - Country Clipper 60" ZTR
looking to purchase a 3ph disc mower. Anyone have any experience with a certain brand? Likes or dislikes.
   / 3 point hitch disc mower #2
Had a 7 ft. Lely several years ago and it did a good job. I like the models with a drive shaft better than multiple gears down the cutting arm. Several neighbors had issues with all the gears when the units got a little wear on them.
   / 3 point hitch disc mower #3
I've run a New Holland HM235 for 5 seasons now, 5 disk, 6' 8" cut. Runs on 42 PTO HP easy.
Oil is changed in cutter bar and gear box every year and blades are flipped/replaced each season.
Works great, I'm happy with it.
The 234/235/236 are economy mowers, so not sure on your usage, but "economy" suited us fine on price.
   / 3 point hitch disc mower #4
Around here, Kuhn is king of the hay mowers. I have a Kuhn GMD600 Gen II, HD that's 5 years old and a JD 265 (also a Kuhn GMD600 with green paint) that's probably 12-14 years old. (don't know exactly, I bought it used)
About the only maintenance that I do is to change the gear oil in the box and bar. The older mower, my JD 265, needed the plastic pivot bushings changed a couple years ago. That's it so far.
I usually cut my entire 52 acres before I flip or change the blades. And, even then, it's more for my convenience. I could cut longer before changing, but it would be right in the middle of my cutting.
Just a tip, but you might want to post this in the HAYING section.
   / 3 point hitch disc mower #5
I also have a Kuhn. Gmd600hd " I think "7'10" cut. It may not be the best, but I sure do like it. It is set up with a system were once you lower the 3 pt hitch the hydraulic cylinder will raise and lower the cutter off the ground for making turns.
I have used other brands and much prefer the operation , not having to lift the 3 pt every time I make a turn. Just make sure what ever mower you choose take the time to set it up properly. Makes all the difference in the world, a great mower not set up well will cause serious head aches.
Good luck and have fun shopping
   / 3 point hitch disc mower #6
I spent 10 minutes spacing and punctuating for the grammar police and it still didn't help.
Sorry ( not really )
   / 3 point hitch disc mower #7
Best advice right there, correct hitch geometry and settings make mowing a pleasure versus a pain. Follow the book a guideline then adjust to suit tractor.
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
2006 TEREX OEGSIB 1412 TRAKPACTOR (A53426)
2006 TEREX OEGSIB...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
John Deere 853 20ft Corn Head (A53473)
John Deere 853...
2007 Utility 3000R 53ft T/A Reefer Trailer (A51692)
2007 Utility 3000R...
