3 point hitch damage -- not having a good day today.
   / 3 point hitch damage -- not having a good day today.
Here are a few of the pics I was able to get today. Camera was not cooperating with uploading to the computer so it took a bit to get er done.. bent lower left arm.JPGcracked connector in place.JPGcracked connector pulled apart 2.JPGcracked connector pulled apart.JPG
   / 3 point hitch damage -- not having a good day today. #12
It is hard for me to tell, but that might not be as bad as I was fearing. Is the broken part separable from the housing?
I didn't try to pull it all the way out but I believe the broken half of the bracket may come out. The large pin you see is the bottom portion of the upper arm hydraulic cylinder and I'm guessing that's what holds the cylinder in place. Unless I'm missing something I don't believe the other side of the bracket will move as it appears to be attached to the housing.
Thanks countrybumpkin! BTW, when I try to go to the link you provide all I get is the following message in the browser "MobileView Not Available" Any thoughts?
Thanks.
   / 3 point hitch damage -- not having a good day today. #17
Been There done that. It's posted here in the Forum for most to see. My guys at West End repaired it and its as good as new
It's not cheap to fix:frown:
Thanks NC49N. I did go back and review your previous post and while its not quite the same I'm also suspecting this will be an expensive lesson to learn. My tractor is still under warranty so I've about decided to take it back to the dealer for the fix.
   / 3 point hitch damage -- not having a good day today. #19
I've bent the same arm on my machine twice.
Easy enough to bend back with a shop press or log splitter, as was noted.
   / 3 point hitch damage -- not having a good day today. #20
The arm is the least of his problems
RING 2 STARTS HERE @ 9:15 AM (A58375)
RING 2 STARTS HERE...
2015 FREIGHTLINER CORONADO 122 SD (A58214)
2015 FREIGHTLINER...
2022 Vermeer 573 (A55973)
2022 Vermeer 573...
2022 Horizon Trailer (A55973)
2022 Horizon...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
