3 point hitch and deck adjustment
   / 3 point hitch and deck adjustment #1
Kjenkins
Kubota 2006 bx 2230
I have a 2006 kubota bx 2330. When I work with the three point hitch the mmm deck goes up and down also. Is there a way to keep the deck at the top and still work with the 3 point hitch?
Also how do you adjust the mower deck height? I have only ran it a few hours. The only way I see to adjust it is with the gauge wheels.
Thanks in advance. Kenny
   / 3 point hitch and deck adjustment #3
Raise the mmm and 3ph to the top using your hydraulic control. Then turn the mmm cutting height control to the top position. If every thing is working correctly, the mmm deck should stay at the top. Then you can use the 3ph as you wish with out the mmm deck moving.:thumbsup:
Hope this helps.
   / 3 point hitch and deck adjustment #4
I missed the part about adjusting the deck mowing height.
Raise the mmm deck to its highest setting(top), and then set the cutting height dial to desired cutting hight. Now lower your deck and it should stop at
the hight you selected.
Good luck.
Thank you all for the information.
Kenny
2018 WACKER NEUSON EZ36 EXCAVATOR (A51246)
2018 WACKER NEUSON...
GRADALL XL3100IV MOBILE EXCAVATOR (A51406)
GRADALL XL3100IV...
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
(1) DBL DOOR REFRIGERATOR (1) VISSANI REFRIGERATOR (A51248)
(1) DBL DOOR...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
