3-Point Hitch 3 Point Drags Motor Down
   / 3 Point Drags Motor Down #1
thcri
Elite Member
Minnesota SE
New Holland TC29D, 2001
On my TC29D when I lift the 3 point all the way up it drags the motor down. If I back it down just a tad the motor runs fine. I am sure it is an adjustment but with moving my manual is not the easiest to find right now. Any suggestions by anyone?
   / 3 Point Drags Motor Down #2
very likely at top of normal travel it is not unloading and thus further attempt to travel is then deadheading the pump and forcing the relief to open.
I'm not up on the jap subcompacts.. but I certaintly have seen SOME units of many different flavor tractors ) that use external control linkage that is adjustable with rods and feeler type setups.
very likely your out of range movement / linkage adjustment is the issue.
   / 3 Point Drags Motor Down #3
ps.. take a look at the exploded parts diagram on the NH parts site to see if you see any external control linkage. I'm at work on a phone.. so not so easy or i'd do it for you.
Alternately. smartman mr RickB likely knows right off the top of his head. He's a NH guy.
   / 3 Point Drags Motor Down #4
Also make sure your draft control if off, it it's equipped with it.
   / 3 Point Drags Motor Down #5
Go back to page 15 of this site and look for TC 29 hydraulic problem and the page from the operators manual is displayed. Simple adjustment and its cured.
   / 3 Point Drags Motor Down #6
Yeah, Soundguy said it. Pretty standard stuff. Find the feedback linkage and loosen the lock nut. Start up and raise the 3PH to the top. Working quickly, adjust the linkage till the bog goes away, and give it one extra turn before tightening the lock-nut. (Longer or shorter depends on push or pull linkage connection .. one way or the other.) Until then all you lose is a bit of lift height by backing off. No harm, no foul. :)
(Ok, Halftrack, .. you type faster ... :eek:)
Thnx much everyone. I will get the manual out in the next few days. I was thinking the linkage may need adjustment.
   / 3 Point Drags Motor Down #8
if it has external linkage. should be easy to observe action without the manual even..
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A56436)
LMC 2-Row Planter...
1629 (A57192)
1629 (A57192)
2017 Jacobsen Greens King IV Plus Reel Commercial Mower (A56857)
2017 Jacobsen...
2016 Ford Edge SUV (A56859)
2016 Ford Edge SUV...
3PT PTO POST HOLE DIGGER (A52708)
3PT PTO POST HOLE...
2019 FORD E350 16FT BOX TRUCK (A58018)
2019 FORD E350...
