3-Point Hitch 3 point carry all
   / 3 point carry all #1
ERE
Northern VA
Kioti CK25 HST
Does anyone have a 3 point attachment for carrying things that they are satisfied with?
I am going modify my tow sprayer to mount on the 3 pt. hitch so I can ease maneuvering problems in the vineyard. I don't need much weight carrying capacity. The sprayer will weigh less than 500 pounds when full. I see the one on Northern Tool and it looks good, but is bigger than I need and, of course, I'd like something less expensive if I can find it. I'd make one, but I'm new to welding and I don't trust myself enough yet. All I really need is a blank platform that I can mount components on.
   / 3 point carry all #2
Tractor supply sells them for about $120. It's on my wish list. They are basically just welded together angle iron with 3 point pins. Could easily be made cheap enough if you have access to cheap steel. Otherwise, don't see how you could make it a whole lot cheaper than $120. I've been looking for one used on craigslist. But, they are few and far between.
   / 3 point carry all #3
KK carry all with 1000 lb capacity @ $120, a few of old lumber if yo have or some new ones and you're good to go. I have gotten way benefit more than total $130 I spent on mine. it is a perfect platform for pump, generator, water tank or what have you.
JC,
PS, There is no way you can buy material and the consumable for $120 to build this. You'll a port-a-band saw at the least. I bough a batch of misc steel for the guys at work to make some bracket. I bought a few sticks of smaller than 2"wide stock and paid around $200.
   / 3 point carry all #4
I bought a cheap bolt together model - working limit of 500 lbs. Worked fine for small jobs, but I always seem to ask too much of my equipment.
I kind of overloaded it last time I used it, not wanting to make two trips up to the garage with the leftover bundles of shingles. Voila, instant pretzel! :eek:
   / 3 point carry all
Great carry-all JC. I could do a lot of things with something that big. It is a little more than I need for my sprayer, however. I want to build the sprayer onto the platform so I don't have to assemble it every week (grapes take a lot of spraying, depending on the weather) - basically that means I'll dedicate the platform to a single use.
I checked the TSC web and see the frame they have. I think it will work just fine. I'll check it out next time I'm at my local store.
Thanks all,
E
   / 3 point carry all #7
I bought the Tractor Supply model about three years ago for hauling firewood. It works great and was 99.00 at the time. Added some 2 x 10's and made it 60" wide like my wheelbase, then added some scrap plywood to the sides. I back up to the splitter, raise it to the proper level, split and stack - saves time and when it's full, I'm usually ready for a change so off I go to unload. Got some pictures somewhere. For the money, you can't make one that inexpensive plus the time involved.
   / 3 point carry all #8
2010 FORD F150 WORK PICKUP TRUCK (A52141)
2010 FORD F150...
Wacker Tamper (A47384)
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2008 Ford F350 Bucket Truck (A47384)
2008 Ford F350...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
E-Z Trail 680 Head Cart (A50514)
E-Z Trail 680 Head...
