3 point blower agrimetal , not impressed .
/ 3 point blower agrimetal , not impressed . #1
Sprinklerman
Platinum Member
severna park
New Holland 1925 Kubota bx 24
I had the opportunity to use an agrimetal 3 point blower , its their mid size , just right for my 35 hp tractor . I am not impressed at all ,yes it blows leaves but no where near as good as a 8 hp little wonder push blower I have . One problem is the deflector is inside the discharge area , no way to dirrect the air flow down to loosen up leaves . I am going to try to make something to stick on the end to possibly increase the velicoty and direct the air down. But as of 2 hours using it , I am glad I havent bought one .
/ 3 point blower agrimetal , not impressed . #2
For the money buying the largest little wonder three wheel walk behind and building or buying a three point tool caddy like the ones advertised on the forum here for your three point hitch to lock the blower in place and carry it around with the blower running wide open will be a bettwer way to manage your leaves.
It would be easy enough to have a reducer tube made at a welding shop for the little wonder leaf blower but they may also have attachments like that for it.
Lots less money and you wil have better results.
After looking at the video , there is a different air deflector on that one to direct a bit more air down . Time to break out the welder .
/ 3 point blower agrimetal , not impressed . #5
H,mm did you buy this blower new?Just curious?
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
KOMATSU PC 200 EXCAVATOR (A65643)
KOMATSU PC 200...
John Deere Telescopic Lift Arms (A65640)
John Deere...
New/Unused Electric Winch (A65583)
New/Unused...
90in. Work Bench (A65640)
90in. Work Bench...
