3 point beast of a STUMPGRINDER checked off my "attachments to buy" list today
   / 3 point beast of a STUMPGRINDER checked off my "attachments to buy" list today #34
Re: 3 point beast of a STUMPGRINDER checked off my "attachments to buy" list today
Hey Piston ... old thread, but I'm starting to shop for grinders again. I saw in another post that you thought the SC25 (or the woods TSG50) would be a more appropriate size for our sized tractors ... do you still feel that way? If I'm shopping new, and paying new prices, would I be better off spending say $4500 for the 24" wheel models, or $6000 for the bigger 34" models? $1500 (or whatever it works out to be) pays for another implement & plenty of spare teeth! If however it's worth jumping up in size, if I do it quasi-commercially (whatever jobs come up) IF our machines actually make use of that size.
OR --- do you think we'd be just as efficient with our (just under 50 HP) size using a smaller wheel?
Thanks.
TSO,
I run the TSG-50 on my 49HP Kioti and it is awesome I've ground 100's of stumps.
It is almost the perfect size for our tratctors in my humble opinion.
Thanks,
David
   / 3 point beast of a STUMPGRINDER checked off my "attachments to buy" list today #35
I noticed in the O/P that mention was made about missing teeth and the owner not being too carefull. I have a vermeer 665A, quite the monster of a machine! If you have stones, your're gonna hit them. My machine will do a six foot stump like nothing and that's alot of stones that the tree has pushed off to the side while growing or mixed in with the roots, and your simply gonna hit them. And they can go flying, let me tell ya! Fortunately we have mostly soft limestone around here! I can operate my machine with a remote, and this is extremely handy to see exactly what you are doing. Once you do hit a stone, and you didn't send it flying, you can kind of try and avoid it.
Thanks.
I think for our size machines, you'd be better off with the smaller model. It would "fit" the tractor better. My stumpgrinder/tractor is sort of the "tail wagging the dog" situation. It really is a large fit for my tractor. Regarding efficiency, I can't comment because I've never run BOTH the small model and my model, it would be interesting to do a comparison though.
Regardless though, if you aren't doing this for a full on commercial operation, you will be more than happy with the smaller model, probably more happy than the larger one. The reason I bought this stumpgrinder was because it was so cheap and in nearly new condition. If I were buying new, I would have bought the smaller (cheaper) stumpgrinder, and used the extra money for something else.
In my opinion, you should buy the smaller model as it's a better fit for your tractor, cheaper, and will put less stress on your 3 point hitch. Then, take the extra money and upgrade your chipper to a BX62R with hydraulic feed. You'd be amazed at how fast you can make an entire tree disappear with the FEL grapple to move the logs, the chipper to chip the brush, and the stump grinder to completely grind the stumps! It's amazing how efficient one machine with a good operator really can be :thumbsup:
The ONLY reason I would recommend the larger model stumpgrinder, is if your planning on upgrading one of your tractors to a larger hp tractor. The larger grinder does work perfectly fine on my tractor, and when I eventually upgrade to a larger tractor, I can take advantage of all that extra capability the grinder has. This thing would absolutely DEMOLISH stumps behind a 70hp+ tractor!
If your not planning on an upgrade, I wouldn't bother going big, it would just be a waste of money.
I agree that a dedicated stumpgrinder will do a LOT more in a LOT less time than a PTO mount. There really is no substitute for a dedicated machine.
That being said, *I would never trade my PTO version for a dedicated grinder, even though it's not quite as capable of grinding stumps as quickly. 6' stumps are a non issue as well, in fact, the size of the stump is a non issue, it just takes longer the bigger it is. :D
(*Unless my primary purpose was dedicated stump grinding.)
Regarding rock... I've replaced about 8 or 9 teeth since getting this, mostly because they were missing when I bought mine, and since then, I've been pleasantly surprised at the durability of the teeth. I do a lot of my stumpgrinding in rocky areas, and I have sent more than my fair share of granite rocks flying through the air. I've gouged granite ledge by accident and have sent sparks flying many times. It certainly doesn't prolong the life of the teeth, but it doesn't do as much damage (as quickly) as I originally was worried about.
   / 3 point beast of a STUMPGRINDER checked off my "attachments to buy" list today #38
Thanks Piston. The possibility of a size upgrade is one of the 2 reasons I would probably consider the larger grinder over the smaller one. I've found the WorkSaver SG-36 sale priced @ $5200... it's rated for around 40-100 HP. The dealer says that, while my tractor would be at the lower range of horsepower, it should still work fine. The other reason is the weight; I would think that the extra weight of the larger unit would help it stay more stable and not bounce around as much as the lighter one. Thoughts?
Piston, what exactly do you find as a limiting factor when using it on our size tractors? Does it cause the engine to bog down, or do you have to go more slowly when cutting through a stump?
My situation is, I've probably got close to 200 stumps of my own, with more in the future as I cut down more trees ... and I also wouldn't mind hiring myself out occasionally to make a few bucks on the side to help pay for the implement.
Could you ballpark the typical time it takes you to grind an average sized stump, say 14 inches across, and about 12 inches high... call it hardwood for the sake of argument.
Thanks again.
   / 3 point beast of a STUMPGRINDER checked off my "attachments to buy" list today #39
That changes everything :D
I just noticed the the "for sale" in your sig. :D In that case, (and assuming the money isn't a big issue which it sounds like it's not) I think you'd be smart to go with the larger grinder.
Your dealer is spot on. My grinder is rated for 35-100hp and weighs 1200lbs. It works fine behind my tractor, in fact it works really well, perfectly fine, the only difference is that I can't take as big of a bite as with a larger tractor.
The diameter of the wheel is 34" if I remember correctly, and I want to say it's 3/4" thick, so you have a LOT of rotating mass there. Once you get the wheel spinning (I set the RPM's to a high idle, and feather the clutch for a second until it's spinning) then it takes a lot for it to stop. That rotating mass helps out with the lower hp.
I remember reading on here that someone (not sure if it was one or more people) did notice that with the design of the smaller units they tend to be less stable, and put a twisting force on the swinging arm assembly. If you look at the design of the smaller ones, I think they are offset to one side (where the side to side pivot point is) and supposedly isn't as stable. I didn't mention this before because it's sort of splitting hairs and being too "picky" as I don't think it makes a difference in actual use. Hopefully "Foggy" will chime in here, it may have been him that mentioned it in the past.
I wasn't going to mention this before, but since you asked I will. My grinder is very heavy, and because of that, and how the left/right swing arm is mounted in the center, it is absolutely rock solid when planted on the ground and grinding a stump.
Yes and yes :D The limiting factor is good ole horsepower! If I take too big of a bite, and go to fast on the swing, it will cause the engine to bog down. I've stalled it a few times by taking too much of a bite, and hitting the swing cylinder a little too fast. (I probably should have had my slip clutch set a little lighter.)
Honestly, I don't think I would grind stumps any "better" or "faster" with the smaller grinder that is more properly sized to my machine. I think it would "feel" more efficient, since I'd be using up most of the capability of the grinder, but I really don't know if it would be quicker??? It may be, I've never operated the smaller version so I can't say. However, I've never met a stump that even stood a chance against me :D
That's exactly my situation as well. I have a never ending supply of stumps, and occasionally do jobs on the side. People are always impressed with the machine. I've never operated a dedicated stumpgrinder, but I imagine it would cost a pretty penny to get one with a 40hp diesel engine driving it. I've had many comments on how powerful and downright scary it is to be near when it's running. Definitely don't let bystanders stand by!
Thanks again.
14"??? My initial answer is "surprisingly fast." If it took 10 mins then I am doing something wrong! I posted a video (albeit extremely BORING) of the first stump I ever ground on youtube. I set up my phone to video it, and it was the first time I used the stumpgrinder, so I had no experience and it's about as long as it should ever take to grind a stump that size. I'll see if I can find a link, you can check the length of the video and see how long it was. I want to say it took me about 15 minutes to grind a roughly 16-18" stump maybe??? It was white oak. I could do it in probably half the time now.
So much "depends" as usual. On big stumps with shallow roots, I often find myself chasing the roots, it almost takes more time to chase the roots and grind them than it does the stump. I ground a large pine in the fall and had to chase the roots all over creation, I think it took close to an hour and a half to do that ONE stump.
Also, depth makes a big difference, if you want to go 12" below ground, the stump flares out a lot on certain trees, this means that a 14" stump turns into a 24" stump a little ways down.
I suppose the bottom line is, I've never operated a smaller (more properly sized) stump grinder on my tractor, so I can't compare them honestly. However, I am consistently impressed with how much of a beast this grinder is. It's one of those things that just give you a huge shiteating grin every time you use it.
2004 John Deere Gator TS 4x2 Utility Cart (A42744)
2004 John Deere...
YANMAR VIO27-3 (A45333)
YANMAR VIO27-3...
2012 CHEVROLET SILVERADO 2500 (A45046)
2012 CHEVROLET...
2014 WESTERN STAR 4900 SF (A45333)
2014 WESTERN STAR...
2012 PETERBILT 388 DAY CAB (A45046)
2012 PETERBILT 388...
John Deere 855 Hydraulic Rotary Tiller (A44571)
John Deere 855...
