Chipper 3 phase power with single phase backup?
   / 3 phase power with single phase backup? #1
90cummins
Florida Ma.
Ford 1720 SSS 4x4 Turbo Charged
I have 120/208 3 phase power in my garage for my 10hp 3 phase compressor and a 3 phase drill press.
All other equipment is single phase 120/208.
I have a 25KW single phase 120/240 PTO generator and a couple small portables that I would like to use as backup during an outage.
I can do without the 3 phase equipment but would like to move all other circuits to incoming lines 1&2 so I can power the entire shop with the exception of my 3 phase tools.
Does anyone see any issues with this?
Does this affect the electrical incoming meter as far as accurately measuring my electrical consumption when on the grid with line 3 basically unused?
Tim
   / 3 phase power with single phase backup? #2
if the branch circuits are sharing the neutral between the 3 phases, you will have problems
   / 3 phase power with single phase backup? #4
What you need is a transfer switch. They're available at Northern Tool here in Minnesota. This will completely isolate each circuit from the electric utility when using your backup generator. I think they come in sizes of 6, 8, or 10 circuits, and they're kind of pricey. $300 - 700 depending on size and brand. You can do a Google search for "Transfer Switch".
   / 3 phase power with single phase backup? #5
Could you explain a bit more.
What he is refering to is the common practice, especially in three phase systems, of using a multi wire branch circuit (MWBC). In this, in a three phase system, three hots ( X,Y, and Z) can safely share one neutral. If you start jinking with things, and try to convert a full boat (MWBC) to a single phase , you can mistakenly end up with a system where you may have three hot ( A, A, abd B) sharing one neutral. The neutral is now overloaded with double its amperage, and is also not protected by a overcurrent device.
Best to consult a sparky
   / 3 phase power with single phase backup? #6
I know from what I've seen that 240V motors operated at 208V will burn up. Can't remember if the motors were single phase or three phase, but i know the utility service was 3-phase 208V wye connected. : ) There's no reason not to use every hot leg for single phase loads on a wye connected service. You only have the third "wild" leg on a delta connected service, like 120/240V 3-phase.
I am the modern man...my smart phone smells of diesel & grease.
   / 3 phase power with single phase backup? #7
Many 240v machines will work just fine on single phase 208v. Some won't
KSI Conveyor (A55301)
2013 International DuraStar 4300 Altec L42A 42FT Bucket Truck (A55852)
2013 International...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2019 Chevrolet Silverado 3500HD 4x4 Crew Cab 10FT Flatbed Truck (A51692)
2019 Chevrolet...
