3 ph on 1920
   / 3 ph on 1920 #1
billfires
Southeastern Mass
New Holland 1920
I have a 2000 NH 1920 w/ FEL & 758C BH. The 3ph arms dropped when my dad was using it and now the swing cylinder for the BH is hitting the right side 3ph lift arm. I attempted to lift the arms but nothing happened. I turned the screw to the other position on the manifold without success. Any thoughts or advice greatly appreciated. Thanks, Bill C
   / 3 ph on 1920 #2
Hi Billfires,
On my 1220, the 3PH won't function when the backhoe (756B)is attached (plugged into the hydraulic system). You may need to unplug the rear and front connectors to get the 3PH back up.
Good Luck,
Curt
   / 3 ph on 1920 #3
Yep.. On my NH 1920.. that power diverter block position will make a difference as to wher ethe oil goes, and when.. And also.. how is your backhoe plumbed? If it is ofo the 3pt handle, wanting it in the up position.. you may just have to disconnect it. Alternately.. something inthe 3pt may have given out.. perhaps a relief valve.. not letting the 3pt build pressure to lif the arms.. etc.
good luck
Soundguy
   / 3 ph on 1920 #4
You will have to disconnect the power beyond hose going to the backhoe and re-connect it to the tractor's distribution block to activate the hitch. Moving the selector on the distribution block only disables the loader and backhoe in this instance, it won't enable the hitch.
   / 3 ph on 1920
OhioGuy, Soundguy, and Rick B, thanks for the replies, I will try connecting the fitting to the distribution block. Thanks again, Bill C
   / 3 ph on 1920 #6
It seems the manuals for this series tractor is really lacking. My recent post about the panel lights sort of illustreates that. I had several problems with my three point after I bought the tractor, they were all cockpit error but not addressed in the manual. I bought an aftermarket manual hoping it would help,
it is a very good manual but was strictly service.
Good thing this board exists to get help when you need it!
Curt
   / 3 ph on 1920 #7
I have a 1720 with loader & 1 set of factory rear hyd ports.
So, where did you get the aftermarket service manual? I only see them for older tractors, have never run across one for a newer series like the 1720. Would be interested in one...
As to backhoe, with my setup could I just use the rear port to run a backhoe by locking the lever in the 'run' mode, and not work about a divider or power beyond port, etc.?
--->Paul
Mini Excavator Quick Coupler (A57149)
Mini Excavator...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
Self Leveling Rotary Laser (Survey Equipment & Grade Control) (New/Unused) (A59225)
Self Leveling...
JOHN DEERE 6000 HI-CYCLE GREEN TOP SPRAYER (A52708)
JOHN DEERE 6000...
2001 THOMAS 140HN PASSENGER BUS (A52708)
2001 THOMAS 140HN...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
