shooterdon
Super Member
- Joined
- Nov 24, 2012
- Messages
- 5,477
- Tractor
- 2019 LS XR4140 HST Cab; 2025 Moto UForce 1000; 2021 Bad Boy 54" ZT Elite
I am planning to modify my firewood processing method next year. I will need a grapple on the FEL for loading logs onto the feed rack of the processor and a set of forks on the 3PH to handle bins of wood that will weigh 1500-2000 lbs. The bins are modified IBC totes.
I currently use a TSC carry all to hold 850 lbs of ballast when using the grapple. It is rated for 1500 lbs. I think that it will be light for handling totes
Most of the Cat 1 forks I have found are rated at 1500 lbs. Some are tubes and I prefer solid forks that will be easier to slip under the bins. Does anyone use or know of a higher capacity Cat 1 set?
This is one I am currently looking at
Titan Attachments 3-Point, 36-in Pallet Fork Hay Frame Attachment with Rack, Receiver Hitch, Spear Sleeves Fits Cat I & II Tractors
Thanks,
Thanks,
