3" or 4" PVC for septic
   / 3" or 4" PVC for septic #31
Re: 3\" or 4\" PVC for septic
Back in 1961, when we built our last house (in the suburbs), my father did ALL the plumbing. He was an old-timer (soil pipe & lead joints). The neighbor across the street asked if his soil pipe drain line should be 3" or 4", as he was considering the "bigger is better" route. My pop's justification for using 3" over 4" was that you would get a better "wash-out" with the 3" which would keep the top of the pipe cleaner, 4" would be more prone to corrosion along the top of the pipe. I witnessed this first hand about 25 years later (mid 80's) in a house a friend bought. We had to replace a couple sections of that rotted out along the top, in his approximately 50 year old drain.
Yea, I know, this doesn't apply to plastic vs. cast iron, but thought it might be worth considering (keep the inside of the line cleaner), or at least of slight interest to some of the old-timers.
BTW, we moved from that 1961 house 18 months ago & the 3" cast iron soil pipe was still in excellent (like new) condition. Current house is two manufactured ranch style connected & all drainage is plastic (4" sch40 main, one bath is almost 100 ft from the septic).
   / 3" or 4" PVC for septic #32
I was in the local Lowe's store and was checking out their sewer lines. Both were schedule 40, blue in color, one had a bell end which would be glued (I guess), and the other had a bell type end but with a rubber gasket inside. I gather with the gasket one you shove the male end into the female end and the gasket keeps everything tight. /forums/images/graemlins/smirk.gif Is one better than the other?
   / 3" or 4" PVC for septic #35
</font><font color="blue" class="small">( I was in the local Lowe's store and was checking out their sewer lines. Both were schedule 40, blue in color )</font>
Go check again...
The blue pipe should say "SDR 35" on it. It is usually used for irrigation or storm water drainage. The regular PVC fitting will not fit the blue pipe.
You can get regular 4" SH40 PVC, in 20' lengths, with the bell end at a plumbing supply house like Northeastern Supply. It is far better to use this underground for two main reasons...
1. 1/2 the # of joints compared to the 10' lengths the BigBox stores sell.
2. The bell end gives a joint overlap of about 6" or so, so you have a much stronger joint as opposed to using the regular couplers that only give about 2" overlap on each side of the joint.
Hope this helps...
   / 3" or 4" PVC for septic #36
Go check again...
Hope this helps...
</font><font color="blue" class="small">( </font><font color="blueclass=small">( I was in the local Lowe's store and was checking out their sewer lines. Both were schedule 40, blue in color )</font>
Go check again...
The blue pipe should say "SDR 35" on it. )</font>
Thanks Kenny. I'll double check when I go back to Lowe's and you're right about the longer pieces. I'll also check the supply houses. If I understand you correctly you're suggesting I go with the large bell type glued pipe vs. the one with the rubber gasket, (which is not glued), is that correct? Again thank you.
Go check again...
   / 3" or 4" PVC for septic #39
If I understand you correctly you're suggesting I go with the large bell type glued pipe vs. the one with the rubber gasket, (which is not glued), is that correct? Again thank you. )</font>
Yes, glue type for sure for plumbing DWV (Drain,Waste & Vent).
The gasketed pipe is used mostly for storm drains.
   / 3" or 4" PVC for septic #40
UNUSED FUTURE MINI EXCAVATOR HYD THUMB (A51244)
UNUSED FUTURE MINI...
UNUSED FUTURE MINI SKID STEER PALLET FORKS (A51244)
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
Komatsu PC138 (A50490)
1996 PETERBILT 379 T/A DAY CAB ROAD TRACTOR (A51243)
1996 PETERBILT 379...
