3" or 4" main septic line?
   / 3" or 4" main septic line? #1
5030tinkerer
Iowa
Kubota GL3830/GL5030
3\" or 4\" main septic line?
I am building a new house and am at the point where I need to install the under basement slab plumbing. I have always been under the impression that bigger is better and have noted that all the homes I have ever toured used 4" septic/sewer main line. A builder that I spoke to today, however, indicated that with the low-flow toilets of today, that a 3" main line is better than a 4" since the 3" will allow a greater water level height in the pipe, thus doing a better job of getting the blackwater (the waste from the toilet) to successfully get flushed out of the line with each toilet flush. I can only set this line once. What do you guys think is better, a 3" line or a 4"? Does this opinion change for the line leaving the house going to the septic tank?
   / 3" or 4" main septic line? #3
Re: 3\" or 4\" main septic line?
We have 3 full baths, all low flow toilets and I used 4" pipe for as much as possible. 10 years later, no regrets. In highschool I worked for a plumber, we never ran 3" if we could run 4". Bigger is better and make sure you have the right pitch and keep your outside run as short as possible. I put in 2 1000 gallon tanks to keep my runs short. Overkill for sure, but I'd do the same today.
   / 3" or 4" main septic line? #4
   / 3" or 4" main septic line? #5
I'll second that. 4" is the way to go. In 30 years we have never plugged ours up.
   / 3" or 4" main septic line? #6
   / 3" or 4" main septic line? #7
When building my 5 bdr/3 bath home several years ago, I posed this same question to the plumbing contractor regarding main lines and branch lines. His response was similar to the one you received. However, sizing requirement is a basic calculation and specified in the code.
   / 3" or 4" main septic line? #8
There are no codes or inspectors where I am building. That is not so much the concern as what will be better. I obviously do not want clogs. The home will have four bathrooms (two full, one 3/4, one 1/2). All four toilets will be 1.6gpf or less.
2009 NISSAN Murano AWD SUV (A53424)
2009 NISSAN Murano...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2016 Nissan Altima 2.5 Sedan (A54815)
2016 Nissan Altima...
2010 Club Car Electric Cart (A53424)
2010 Club Car...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A55301)
2020 Westfield MKX...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
