3 or 4 bottoms behind NH TD5050
   / 3 or 4 bottoms behind NH TD5050 #1
peter_vii
Ontario
B2320N, JD5083E
Hi there,
I was wondering it NH TD5050 would pull 4 bottoms plow in a loamy soil.
Some fields have not been worked in 30-40 years.
Or should I just buy 3 bottoms to save money.
Thanks,
Peter
   / 3 or 4 bottoms behind NH TD5050 #2
I believe that's a 62 hp tractor???
I pulled a 4-16 bottom with a 7700 - 85hp tractor. All it wanted.
Now I'm pulling a 4-18 plow (4 bottom, 18 inches each) with a 130 hp tractor, & it works much better.
I have difficult soils. Your milage may vary. 15.5hp per bottom??? Wow. Wish I could do that, save a lot of fuel. Good luck if you try the 4 bottom.
'Here' a good 3 bottom plow will sell for a lot more than an equal 4 bottom plow.
--->Paul
Tractor is listed as 80HP PTO, 93HP engine.
I don't trust the manufacturer's specs. I rather see an independent
(Nebraska) test to see the exact HP that goes into the ground.
3 bottom reversible (JD 975) is listed 2K less than 4 bottoms.
Maybe 3 bottoms will be more suitable to a 80HP (PTO) tractor?
   / 3 or 4 bottoms behind NH TD5050 #4
Oh - 80hp - then a 4 bottom could work fine in better soils than I have. I tried looking up the hp on-line & took the first scketchy info I ran across...
Where I live plows are being sold for scrap & cut up, you can buy a 4 bottom JD 145 for $150 any day of the week. Can't see anyone paying $2000 for a plow 'here'. The smaller 2 or 3 bottom plows are more popular for the hobby folk with smaller tractors, so they will bring $500 or better. And folks with farms buy the 5-8 bottom plows so they still have value. But right 'here', 4 bottom plows are pretty much a dead market - too big for hobby, too small for real farming.
--->Paul
   / 3 or 4 bottoms behind NH TD5050 #5
I would go with the three bottom but much depends on your soil. I am using a 4 btm IH plow behind a 140 hp tractor and there are many spots I would not want anything bigger. Even with a 4btm you feel like there is a lot of plow back there. Easier turning, more manuverability with the 3 btm.
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2011 Chevrolet Colorado LT Pickup Truck (A50323)
2011 Chevrolet...
2011 PETERBILT 367 TRI-DRIVE WITH TAG (A52472)
2011 PETERBILT 367...
UNUSED AGT QNT30 EXCAVATOR (A51243)
UNUSED AGT QNT30...
