3 cyl vs. 2 cyl?
   / 3 cyl vs. 2 cyl? #1
Ginormous
Dayton, Ohio
Yanmar YM2210
Hi guys,
Any fresh opinions on 3 cyl vs. 2 cyl? I understand the 3 cyl engines run more smoothly. What other differences? Noise? Fuel economy? etc?
   / 3 cyl vs. 2 cyl? #2
On a two cylinder there is a longer time between the firing of the pistons. Although I dearly love the old John Deere two cylinders they don't make them anymore.
   / 3 cyl vs. 2 cyl? #3
My 3 cyl is very good on fuel.
   / 3 cyl vs. 2 cyl? #4
My experience is that the 2 cylinders are louder but more user friendly, since the power band is flatter. They will pull their load at lower RPM than the 3 cylinder engines. I think they are all too loud, and always wear hearing protection. The 2 cylinders make a lot of noise from the engine. A better muffler wouldn't really help. The 3 cylinders are smoother, and the sound is attenuated better. Additional muffling might dampen the sound even more.
Fuel economy is excellent for either type, with an insignificant edge to the twin cylinder. There really isn't much to choose as fuel consumption goes. All of them impress me, especially every time I run my 17 hp gas engine riding mower.
For reference, I have 14 and 15 PTO horsepower rated versions of the 3T72 in my 1401D and 186D respectively, and the twins are all some 2TR20 variant. My 186D is fortunate to have Powershift. It is very heavily ballasted, and really benefits from the ability to start off in first gear and shift up up and down to keep the RPM in the working range. My YM240 with a loader weighs the same or more, but will start in any gear from idle, and clank away happily. The 186D has no hope of doing that, and needs to be above about 2000 RPM to do much good, but the transmission lets it stay there. My 1401D has a loader but is quite light, compared to the 186D, and the power is much more tractable. I always run out of traction before power with that machine.
I don't advocate lugging the engines, and the 186D shows excellent fuel economy, so isn't suffering from being revved up, but the big two cylinders are very affable and friendly to deal with.
Others may have different thoughts or experiences.
   / 3 cyl vs. 2 cyl? #5
I know what you mean. I have a 22 HP on my zero turn. I have to re fill the tank with gasoline so, I can finish mowing.. I can fill my yanmar & run all day:thumbsup:
   / 3 cyl vs. 2 cyl? #6
I have had or delivered boats with, 1/2/3/4 ect. cly. Yanmar engines. The more the better as they get quieter mostly because of the smaller injectors,
Wistleplig, I to miss the old 2 cyl JD's had one on the family farm for mowing and raking the hay.
   / 3 cyl vs. 2 cyl? #7
The Only experience I have personally is with a 2 Cyl on the YM 2000. It has the yammer hammer but as discussed elsewhere and before my fuel efficiency is incredible. I can have a 1/4 tank and have learned I can decide to bush hog my pasture and not use it all and when the tank is full it seems to last forever. Anectodal for sure but outlast my friends 3 cyl Kubota by leaps and bounds. Power has always been there for anyting I have asked it to do.
   / 3 cyl vs. 2 cyl? #8
A lot of variables come to mind for the two cylinder. Inline, Opposed, V configuration?
Then on to comparing them; bore and stroke, valve train, RPM, balancing, etc etc.
Chances are well designed two or three cylinder engines will be quite comparable in operation.:)
Just think about the 60 degree V twin as compared to a nice opposed twin??:thumbsup:
   / 3 cyl vs. 2 cyl? #9
I have had both and like the 2 cyl better. 3 cyl was smoother with less vibration but it was just as loud, ear protection is a must with any yanmar I have used.
   / 3 cyl vs. 2 cyl? #10
I have a 2 cyl mitsu in my Satoh beaver 4wd. (15hp)
I have a 3 cyl kubota in my garden tractor. (19hp)
The 2 cylinder seems to have tons more torque and gets better GPG (grass per gallon)than the kubota. The kubota has to be screaming, and I think the hst robs a little power too. the Satoh beaver only has a 2 1/2 gallon tank (maybe 2 3/4 gallon) and will run all day long draging dirt, a finish mower etc and still have plenty of fuel left in it. I'm honestly amazed at how effiecient the little mini tractor is and how capable it is.
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
FAKE (A52472)
FAKE (A52472)
CFG Industrial SAII100 (A50123)
CFG Industrial...
