3 cyl 2000 Rear differential swap
   / 3 cyl 2000 Rear differential swap #1
lxrubin
None yet
I have a mid 60's 2000 3 cyl gas 4spd with no diff lock or live PTO. Basically a base model as far as I can tell. Someone in my area is selling a complete differential and I'd like to know if it would bolt up and be a direct swap in my tractor. I imagine the live PTO function is based on the transmission, but if I could gain diff lock, external hydraulics, and maybe a higher gear ratio (slow the tractor down) I may consider it.
And this is the rear end currently on my tractor.
   / 3 cyl 2000 Rear differential swap #3
It will bolt up but the PTO driveline probably won’t match up. You have a transmission PTO and the donor probably has IPTO.
What would need to be done to gain ITPO? A different transmission I presume? and probably all the associated linkage?
Is the gear ratio in this diff different than mine? Or impossible to tell by the limited info?
   / 3 cyl 2000 Rear differential swap #5
why not just get a different tractor.lots of older used ones available.
The price is good, and includes good tires. If it's not a viable swap option then I'm not going to pursue it. Just wanted to know what my options were.
   / 3 cyl 2000 Rear differential swap #7
#1 you need a live driveshaft from the crankshaft to the IPTO clutch. You do not have that, and will not without the transmission and flywheel that goes with that donor rear end.
#2 you need the PTO clutch input in the donor rear end (if it is even there) to mate up to the shaft referenced in #1 above.
Long story short, your dream is just that. The wheel lug bolt circle and pilot diameter are not a match either.
Thanks for the info. I'll be passing on this idea
Case 950 8 Row Air Planter (A56436)
Case 950 8 Row Air...
Massey Ferguson 4608 (A53317)
Massey Ferguson...
2005 Peterbilt 387 with Wet Kit (A56435)
2005 Peterbilt 387...
7066 (A56857)
7066 (A56857)
202474 (A54757)
202474 (A54757)
2017 Ram 4500 Bucket Truck (A55302)
2017 Ram 4500...
