.3 amps is how many watts?
   / .3 amps is how many watts? #1
Richard
Elite Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I've looked on internet for calculator. Thus far, not been able to find one.
Trying to add up the wattage used in the bathroom so I can get some prewiring done prior to my bro in law "checking it out" for me (he's electrician).
I don't want to infringe on his help too much so I'm planning on dividing 2 circuits up in the bathroom on "my" time so that I only use HIS time to double check.
Thanks
/forums/images/graemlins/smile.gif
And I do mean .3 amps, as in decimal 3 = watts?
   / .3 amps is how many watts? #2
Volts X Amps = Watts
Assuming you're using 110 volts you're looking at about 33 Watts /forums/images/graemlins/smile.gif
That's what I thought (and used) but it seemed WAY too small of number for a bathroom exhaust fan???? I would have expected more watts used.
   / .3 amps is how many watts? #4
That seems about right, half of a 60 watt bulb. Probably a small fan?
   / .3 amps is how many watts? #5
The big electrical loads in a bathroom are the things that make heat.
Electric heaters, if you have one, and electric hair driers.
If the bathroom is big enough that you think you might ever use his and her hair driers in there at the same time, put the convenience outlets for them on different circuits.
Other than that, it is really difficult to use enough electricity in a bathroom to overload two circuits. The usual circuit breaker is 20 A, which is 2400 watts at 120 volts. That many watts in a small room will make it very warm, very fast.
Most of the energy a light bulb uses goes into heat.
2019 TY-CROP MANUFACTURING LTD DRY BULK TRANSPORT TRAILER (A53843)
2019 TY-CROP...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A53426)
2015 FREIGHTLINER...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
40 ft. Shipping Container (A53117)
40 ft. Shipping...
