3/8 pipe thread - tapping for fuel bowl
   / 3/8 pipe thread - tapping for fuel bowl #11
rScotty, since you brought it up, I purchased Permatex High Performance Thread Sealant for both the hydraulics and the fuel system (recommended by the Hydraulics place where I purchase my seals, fittings and hydraulic hoses).
The Permatex website states the following: "Stainless steel fittings, head bolts into through holes, oil PSI sending units/sensors, oil and coolant lines, intake manifold switches, rear axle fill plug, and fuel fittings."
What were your findings in regard to thread sealers impervious to gasoline?
Thank you,
I took the technical route to fuel resistant sealers. From my motorcycle & boating days I had done a lot of experimening with sealing gas tanks suspended over hot engines.
The cured material has follow threads, stay flexible, and resist petroleum based fuels plus various alcohols forever. Silica thickened polyurethanes are one group that works. None of the RTVs or silicons I tried worked long term. Epoxies? I don't know.
My favorite "go to" goo for gas tap threads is the time-honored Hylomar Universal Blue - it's an aviation product, but you can probably find it. Get the old style type. which is a proven product, but does outgase when curing so is being replaced by a newer formulation. I've used the old formulation many times. Developed in Britain, maybe by the same engineers that designed machines that leaked so many fluids in the first place.
Let me know how that Permatex works. It would be nice to have an alternative to Hylomar Blue. There are three Permatex products that are similar to Hylomar and might even be better. I just don't have experience & would want to run a few basic experiments just to convince myself they are good.
So I'm still using Hylomar Universal Blue (old style)
The Permatex products I was considering - just based on chemistry - are:
Permatex 80017 Aviation Form a Gasket
Permatex 85420 Orange Permashield
Permatex 80057 300 Form a Gasket
rScotty
   / 3/8 pipe thread - tapping for fuel bowl #12
Hylomar may not be available in Lodi.
I used to overhaul large radial aircraft engines in Lakeport, and we would use Permatex brand Hylomar on the rocker cover and push rod adaptor flange gaskets. Those gaskets never leaked oil IF dressed with Hylomar.
Late 90's sometime, unable to get from parts house. Said the state banned it due to something EPA.
Went to using Permatex 80017 Aviation Form a Gasket. Messy but worked ok.
Used thread lube or fuel lube for pipe thread fittings into Magnesium cases. It was paste in a small can.
Had to be careful with fuel lube as if it got into fuel system, would not dissolve and could cause blockage.
Aircraft Spruce carries these products.
Patrick
   / 3/8 pipe thread - tapping for fuel bowl #13
... Developed in Britain, maybe by the same engineers that designed machines that leaked so many fluids in the first place.
rScotty
:D:LOL::ROFLMAO:(y)(y)
"That's not a leak, its the chain oiler".
'53 BSA here. AJS. Matchless. Austin small sedan that needed a NLA water pump. BTDT!
When the new Honda motorcycles didn't drip, that ended the British bike era.
   / 3/8 pipe thread - tapping for fuel bowl #14
My buddy still has his vintage race bike - an AJS 7R. It is now a living room sculpture. No, it doen't leak; no oil. The drip pan underneath is just for ambiance.
rScotty - still missing the old Gold Star twin. But it couldn't possibly have been as good as the memories it left.
   / 3/8 pipe thread - tapping for fuel bowl #15
NPT connections should not need thread sealant. The seal is metal-on-metal. That's why the threads are tapered, so they get tighter and tighter until seal is achieved. Thread lubricants like Teflon tape are used to help you be able to achieve the tightness required for sealing, before galling and damage occurs.
   / 3/8 pipe thread - tapping for fuel bowl #16
They shouldn't need sealants if the world was perfect and static, but it isn't and they do. Any connection that vibrates or has relative movement benefits from a sealant.
Thank you for the thoughtful replies. If the Permatex HP Thread Sealant does not work, I will try one of the aviation products. (grammar edit)
   / 3/8 pipe thread - tapping for fuel bowl #18
NPT threads do not seal on the crest and or root of the thread only the on flank of the thread by design. Therefore you can have a spiral leak. That is one the reasons sealant is required on NPT threads. The dry seal thread design eliminates this problem. ASME B1.20.3 Dryseal Pipe Threads, Inch - ASME
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
2024 CYNERGY CARGO LLC 7' X 14' CARGO TRAILER (A51243)
2024 CYNERGY CARGO...
2018 Chevrolet Malibu (A50324)
2018 Chevrolet...
UNUSED JCT QUICK ATTACH 84" ROCK GRAPPLE BUCKET (A51244)
UNUSED JCT QUICK...
Super Star Smithco Bunker Rake (A50322)
Super Star Smithco...
2020 JOHN DEERE 333G SKID STEER (A51242)
2020 JOHN DEERE...
