3/4000 power reverser question
   / 3/4000 power reverser question #1
nch209
Northern Virgina
John Deere 3520
New to the small deeres here, sorry for dumb question. On 3000/4000 series compacts, please explain power reverser. It says 12 forward, 12 reverse, but is it just that... 12 selections? I'm used to 7000 series that you pick a range and then can toggle between gears, or older quads that have a high low in each gear, kinda like a TA. Any pics of this layout as far as where the gear selections are made... Like from the operations point of view.
No literature shows it!
Thanks
Nate
   / 3/4000 power reverser question #2
12F/12R power reverser is a electro mechanical shuttle shift forward/reverse no clutching required. It has three ranges A,B,C non synchronized. And 4 Gears 1,2,3,4, that are synchronized clutch required. Gear and Range are on sticks on the right with a forward reverse shifter on the left of the steering column for last few years.
Gotcha. Thanks!
Was hoping the 1,2,3,4 we're push button... Yet I still like this idea. Need to look at it further. Any pics?
   / 3/4000 power reverser question #4
Gotcha. Thanks!
The reverser transmission is really nice and the versatility of 12F/12R fits every application I've come across.
Do be aware the some reverser transmission (the early 4x00 series from 1998-2005 or so) do require the clutch used when changing direction. These are designated "Sync-Reverser".
^. Thanks! I bought an estate and part of the deal was a b7800 kubota. Tough as a tank, but I'm thinking it may be too small for me. Was looking at 3 series deeres, but now 4 series. I like the gear tranny idea, but most everything is hydro. We shall see. May make an offer on a somewhat local 4320. Thanks for the info folks!
   / 3/4000 power reverser question #6
I have a 2012 low hour 3320 power reverser for sale. Am located in southeast ohio. Only 75 hours, like new. Just FYI.
AEROQUIP PROOF TESTER (A53843)
AEROQUIP PROOF...
TOTE OF CONCENTRATED METAL CLEANER WITH HOSE AND DIAPHRAM PUMP (A53843)
TOTE OF...
2016 IZUZU NPRXD S/A BOX TRUCK (A52706)
2016 IZUZU NPRXD...
2010 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2010 FORD F750 XL...
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A53843)
2013 KENWORTH T800...
